Hfl
Hfl
Just purchased an 07. Everything looks and works great except the HFL. When activated, it does not recognize voice commands. is there something that needs to be reset, am I not following the proper steps or is this a repair issue?
mrgold35
I think folks were having problems with the HFL and/or Bluetooth module draining the battery. They disconnect the unit to keep from draining the battery. There is a good chance since your MDX is an 07, this might be the problem.
mrgold35
Here is a link for someone that had the same problem on their 07: https://acurazine.com/forums/1g-2g-m...-where-837013/
PDF in the above thread on how to remove at Post 13: http://ww2.justanswer.com/uploads/ac...42_binder1.pdf
I'm just taking a SWAG (Scientific Wild Ass Guess) as to this being the problem.
I have a 07 MDX and the HFL doesn't even come on. We just had the unit replaced about 2-3 weeks ago. Worked fine when first replaced. When ever you push the button on the steering wheel nothing happens. Any thoughts?
mada51589
05-03-2022 08:54 PM
phillyguerrilla
09-26-2015 11:27 AM
rmittal
1/2G MDX (2001-2013)
09-19-2015 08:41 PM
