Galaxy Wallpaper Help?
Hello Guys, i am trying to have the Galaxy Wallpaper stay on when i startup the car, but it always defaults back to the regular screen and once the car is in motion you can access.
Is there a way to also display the clock on the wallpaper as the 2014-2016 MDX?
same issue here did you ever figure it out? i posted under the transmission thread as well because I am having multiple issues with my car. yesterday the wallpaper screen would not even highlight to make changes to then I got it to and yes when i re-start the car it's gone
mrgold35
I think the best you can do is use the default wallpaper or add up to 5 jpg images if the size is small enough (not sure of the jpg size limit). I have a USB plugged in 24/7 with my music and a folder with the jpgs images I can select. 90% of time it will stay with the one I selected IF is don't hit the "OK" map button. Every once in a while it will select another picture; but, switch back to the original the next time I start the MDX.
