Fuel Cleaner
Rich and Famous
You might want to try Seafoam since yours is used at 150 K.
Better to open fuel engine up and see what it looks like.
Mine is new but ... I switch brands of gas and often mix 89 octane
with 93 octane to remain 91+ and reduce the problems w/ same detergents and ethanol water contamination.
This mixing reduces problems with dirty foul gas supply.
You have no freeking idea what previous owners used
so you might try Seafoam or better yet inspect it.
Seafoam - 1 can (16 oz.) to 8 gallons of gas. Do it now then again in a month or two then you should be good for a year or so.
You can Seafoam through the intake manifold as well.
No, additives in your fuel tank burn through clean. Seafoam only smokes when added through your intake, and even then it's only for a couple of minutes.
Seafoam is good and as well Redline SI-1 Fuel cleaner is great
takin care of Business in
Received 4,732 Likes
1/2 can of seafoam in the fuel tank (when the "E" light is ON)
1/2 can of seafoam through the vac port
1 can of seafoam in the engine oil
When your done with this, I suggest changing engine oil and spark plugs....
rcs86
08-02-2016 06:52 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
joflewbyu2
10-08-2015 11:16 AM
