Flashing d5 light, tranmission wont go out of first gear
Having some issues with my 02 mdx right now. Fuse 6 keeps on the drivers side keeps blowing, which is results in the transmission not functioning properly and the d5 light to flash, and the park and neutral lights to stay lit. I've gone through a box of 15a fuses already, and two things happen. Either it blows right away or it doesn't blow and the car operates normally for a few minutes until it does blow. I've been able to drive the car up and down the street when the fuse doesn't blow and it goes through the gears appropriately, so its same to assume its not a tranmission issue right? Just electrical?
I'm getting codes P1298, P0135, P0141, and P1768. Done some resarch and can't find any concrete fixes to it. I've tried replacing the ELD and topping off the transmission fluid.
there is a wiring issue that needs to be fixed first. The fuse popping means that a wire is getting too much current! Have a mechanic trace the wires from the fuse and see where they may be a cut/pinch.
oldsoul (02-03-2021)
Mizouse
Money & Investing
392
06-06-2024 10:22 PM
yg17
10-05-2013 11:06 AM
