Drivers side noise?
Drivers side noise?
Just purchased a 06 MDX. Seems to be a lot of road noise around the drivers door area? Is there a way to check the door and or adjust? Or should I be looking for something else? Thanks
A pillar wind noise or worn gaskets. A little window rubber weather seal with a P profile helps reduce the noise, but not completely. I also stuffed a piece of foam at the base of the a pillar. With the door open you can see the area just deep to the side mirrors. A little volume adjustment on the radio also helps.
I tried the foam thing and it might have helped just a touch...but if at all, not much.
I purchased the rubber weather seal from Lowes. The seal is placed on the door and the chassis. On the door place a strip starting from the door tweeter and follow to the bottom of the door. A short piece is to be placed on the top forward angle of the door jamb so that it sits between the two factory strips. You can also place a piece of foam on the inside area of the fender the leads into the A pillar (open hood to access the area near the hood hinges). I will try to post a picture or two...
Any photos any of you have would be great, thanks.... I'll try and get that weather seal, thanks!
rockyboy
08-04-2024 10:35 AM
marcelft
07-10-2018 06:17 PM
sockr1
10-01-2015 01:31 AM
