Daytime running lights
Moderator Alumnus
I do not have much experience installing DRL but you will need this part: http://www.hamsar.com/drlkits.htm (45020)
It wont come with vehicle specific instructions but will come with a schematic you can use if you are decent with wiring. Worse comes to worse you may just have to take this Hamsar unit to a local garage and they should be able to do it for you. Good Luck!
thx for the offer...just got them up and running today. A local small shop did it along with the safety and the RIV inspection. Basically the tech just ran a wire from the DRL relay under the steering wheel thru a fuse to a DRL module that was installed in the engine compartment and then ran wires to the two headlights and spiced in. Works fine.
mada51589
05-03-2022 08:54 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
