D-003: Tire pressure
Hi,
What tire pressure are most of you running your MDX's at?
Do you drive usually close to the max for the tire?
Should all tires be the same pressure?
just wondering because I need to correct my pressure.
Sam
Sam
Backs the Pack
Recommended is 32 psi at least for the 18" Michelin's on the 2nd gen.
I try to run at 34 psi and usually only have to adjust before winter and again in the spring.
I think it would be best if they were all equal. Sometimes the TPMS gives me a mixture of 33/34 among the four tires but that's close enough for me.
I drive with the pressure at around 35PSI Cold on all 4 corners, nowhere near the max PSI of 50!
mugen_kid
11-13-2015 10:38 PM
NBP_BALLER
09-23-2015 08:18 PM
CostcoFanAUS
09-18-2015 06:05 AM
HeloDown
09-08-2015 06:51 PM
