CV Boot Leaking - question re repair
Old 05-31-2013, 02:27 PM
23109VC's Avatar
My car was in for service at the dealer and they advised me the driver's front CV boot is leaking and they suggested it be fixed before my axle failed...
the cost for the part/labor is $415.
I have an extended warranty and they advised that the repair WAS covered under my Acuracare warranty... so of course I am ok with having it fixed..but I was just curious if this is a legit issue with the car, a needed repair, or some kind of BS to just make money.
every time I go in for service I swear they try to upsell me crap. I am likely going ot quit going to the dealer as while I do enjoy the loaner service they provide, I'm tired of starting to feel lke they are dishonest or making crap up to make money...
my 2007 MDX has about 85,000 miles on it.
is this a normal wear/tear item at this point? if I was NOT under warranty, is this something you would absolutely fix, ignore, etc?
thanks.
Old 05-31-2013, 03:32 PM
ls973800's Avatar
Yes, it is a legitimate repair. The rubber can be ripped or torn by being hit with road debris. It can also tear just from wear, although I don't think that happens too much.
The boot holds the grease for the axle inside, and when it splits water can get in and grease can get out. If that happens, you can ruin the axle. It has to be repaired and not left in the damaged condition.
I'm glad to hear it was covered, especially since most of them are damaged by being hit with something. Sounds like the warranty did you well.
TLtrigirl (06-15-2013)
BoricuaTL
04-08-2016 01:08 PM
thegipper
10-21-2015 07:19 AM
CaliBud916
09-19-2015 01:56 PM
datadr
09-12-2015 09:12 PM
michaellong77
1G CL Problems & Fixes
09-11-2015 12:54 AM
Quick Reply: CV Boot Leaking - question re repair
