Anyone use an Alternate Tires Size on the stock 18" MDX Rim?
This may be a dumb question... But the TL guys do it all the time. In fact, I did it when I had my TL. Went from the factory 245/45/17 to a 255/40/17 on the stock rim...
Anyways, that is besides the point.
I know this car is an SUV (and it's my first), but the amount of wheel well showing is huge (again, I know it's supposed to be that way, as this is an SUV).
BUT, I thought I would ask if anyone has put (or considered putting) a slightly larger tire on the stock rim to fill out the wheel well just ever so slightly better? If so, what size did you run?
Z06-Track / MDX-Groceries
The tolerance level in terms of the odometer and speedometer differences is going to be very small, ie. it doesn't take much of an increase in size to throw everything off, but there may be a few options.
Play around with one of these calculators and you should find an alternative size that might work:
http://www.discounttire.com/dtcs/infoTireMath.dos
http://www.1010tires.com/tiresizecalculator.asp
What about wider?
In Search Of Sunrise....
I don't think wider will hurt so long as the rim width can handle the dimensions. I'm not sure what the factory specs are on the MDX wheel, but on my TL which has factory specs of 235/45/17, I went with 245/45/17 without issue.
Aesthetically, it looks great! The footprint is wider which gives you more contact with the ground for improved dry traction and it wont throw off the speedometer. But for those of you that live in a snowy region, you might want rethink this as it will hurt you when it comes to driving in the snow.
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
