ABS and VSA problem...
Hi guys! I'm new here. Major issue. I posted it at another forum, but might as well here. It's my Exclamation Triangle Mark and then eventually VSA light will follow. Good thing, I bought a code scanner that also can scan ABS code.
Following is what I got from my scanner.
84-01 ACURA ABS CODE:
1. IG1-2 open circuit
2. VSA Sensor neutral position not written
3. CAN Communication failure (Bus off)
4. Steering sensor input error
5. Steer angle sensor failure
6. Sensor logic failure
7. Target vehicle come closer than the multimeter radar detecting limits
8. Sensor 0 (Zero) position memorization incomplete
9. Sensor 0 (Zero) position not write.
Any ABS out there, please help! I'm completely clueless now.
As always, thanks in advance for any hints, leads, helps, etc...
Anyone else has inputs? I'm pretty driving it with all the problem. Now, Check Engine Light is also on with the same code Cylinder misfired 1, 4 and 6. Replaced all those ignition coils already and swap them around, but still the same codes come back each time.
This was back in 2014 and haven't had any issues since.
