2007 MDX squeak in dash
I've had this car for 3 years and have about 38000 miles on it now. For the last couple of months the dashboard has been squeaking, not just when I hit a bump but also when I drive through a slight dip that makes the body flex. This is not a rattle but just a squeak, like rubber rubbing on plastic. After looking on the internet for an answer I have realized that this is a common problem. I've checked the dash over very closely and nothing is loose. I decided the noise was resonating from the windshield. I checked the plastic cowl cover. There was dirt under the rubber lip that contacts the windshield. I took a damp paper towel wrapped around a putty knife and cleaned it out. The cowl cover doesn't fit very tight. It is held in place with some plastic clips that allow about 1/8 inch of movement. I moved the cover forward as much as possible and went for a drive. No more squeak. It's been 4 days now and still no squeak. I don't know which of the two things I did fixed it. If the squeak returns I will probably replace the plastic clips with screws. Knowing this has become a problem for many MDX owner I just thought I would pass on what worked for me.
CL in lawnmower status
hopefully someone will move this to the MDX section.
Thank you for the valuable first post, feel free to stick around and check out the MDX section to provide any more tips or to read up on tips and tricks provided by other MDX owners
and welcome to AZine
