2007 MDX, changed shock and now steering won't return to center after turning...
You know when you make a turn and you let the steering wheel return to top dead center, well after changing shocks, it wont return... I've had 3 alignments and they keep saying it's not the shocks but that's the only thing we changed and we didn't have the problem before. I'm not looking to keep throwing money at possible problems by the technician. Now they are saying the calipers are sticking which is bs because it happens left or right turns.
Any suggestions?
Any suggestions?
perhaps they damaged the steering rack when they did the work ![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Best thing to do is take it to a shop and have them diagnose it. Alignment affects suspension geometry mainly in a straight line so during turning it doesn't help much. It could be that they installed the wrong shock or didn't install something properly.
Have you tried alignment at a different shop or is it the same shop you did your shocks?
