2007 drivers side door lock actuator
Hey there, I'm having some trouble with the drivers side power door lock. Doesn't work from the fob or the switch.
I replaced the wiring harness between the driver's door and fuse box, but that didn't help, so I think it's the actuator motor.
Does anyone know the part number for this?
2007 MDX driver's side door power door lock actuator motor
Thanks!
Thanks!
72150-stx-a13 should be the drivers door lock actuator, should be around $44 dollars new from acuraoemparts.com, use coupon code acurazine for 5% more off.
drsprite (06-20-2016)
Awesome, thanks!! Now to find a guide on how to do it. I see online how to take the door panel off, then I think the window channel is in the way. Hopefully it's not too hard
On my TL I had to loosen the bolts for the window channel and was able to wiggle out the motor without having to remove the window and channel! Best of luck
IHaveNoIdea2012
2G CL Problems & Fixes
05-09-2016 04:45 PM
