08 mdx starting then stalling right out after a second
So i wanted to make this post to hopefully help someone out bc i couldn’t find the solution to this anywhere and after 3 weeks i finally figured it out. Not sure if this was just a coincidence of this happening or 2 different issues i was having issues with my windows rolling down my sunroof not working & my locks my door harness had broken wires that was causing it to short so in order to open or shut windows i would have to open my door and press on the harness well after doing this one day the truck shut off and wouldn’t start back up i thought it was the battery nope the anti theft nope going through all the fuses i thought it could be i replaced the harness and still nothing locks windows & sunroof still wouldnt work and the lights on the dash wouldn’t work so yesterday i decided to check the fuses again and on the driver side fuse panel there’s a fuse called METER a 7.5 fuse and what do u no pulled it out & saw it was broken replaced it and the damn thing started right up windows all 4 roll up & down no problem sunroof works and dash lights all worked again couldn’t believe that fuse caused all these problems. Hope this helps someone experiencing the same issues.
Welcome to the forums.
Since this is a topic/technical issue which will require replies and discussion, this thread has been moved from the New Member Introductions forum to the model specific forum for better response.
StuartKopple
12-30-2018 02:25 PM
Jonathan Wong
02-26-2017 10:28 PM
