06 MDX won't start in park, starts in Neutral
I apologize if this question has been asked before, I couldn't find it when searching the forums. My 06 MDX (87k miles) won't start in park, but will start in Neutral. New battery and starter so that's eliminated. I read it maybe a neutral safety switch, is there anything else I should be looking for? Thanks in advance for your time..
The shifter is not electronic like the 3rd gen.. You have a Mechanical issue if you start in neutral while the shifter is in Park. If the shifter is in D but feels like Neutral then its another issue.
^^ i think he saying the he can only start when he moves the shifter to Neutral.
Can you check if any other functions like door locking/unlocking etc work when you move the shifter to & From Park?
Then I miss read that, Thanks!
I would assume the range switch is at fault.
crxb
3G RLX (2013+)
03-25-2016 07:23 AM
