'05 MDX rear passenger door removal question
Hi all,
I'm trying to replace my window regulator. I found a really good tutorial on YouTube on how to do it (it's for a Pilot but it seems like it will be similar...for the most part at least), but there is one part about the door removal that I can't figure out.
There is something holding the panel together in the middle, but I cannot figure out where to unscrew/dislodge the peg. If you look at the following
at :58, you will see someone take a screw out. Well, the Acura doesn't have a screw there, however, it seems like there is something similar there. How the heck do I get to it. I've tried taking the leatherish panel off...I've tried looking down the gap between the panel and the door now that is loose. Can't find it! Help and thanks!
tman570
06-11-2019 07:56 AM
