03 MDX VTM-4, VSA, CEL on after radiator replacement
Old 11-30-2015, 12:41 PM
8th Gear
proman's Avatar
Guys,
The radiator on my 03 MDX failed the other day. It's the famous trans cooler adapter and emptied the tranny fluid. I managed to drive the car back home.
After I replaced the radiator, my instument panel is like x'mas time. CEL, VTM-4, VSA, and VSA Activation Warning lights all came on. Car still drives fine though.
Anyone can give me an idea what could cause this? Thanks.
Old 12-01-2015, 03:36 AM
Skirmich's Avatar
Received 1,017 Likes on 867 Posts
You will need to pull the codes for that one.... Autozone is your friend
Old 12-22-2015, 07:40 PM
8th Gear
proman's Avatar
Report back that the problem is solved.
It's the VTEC Rocker Arm Oil switch connector. I pulled it off when draining the coolant from the engine block and forgot to plug it back in. Once I plugged it back in, all codes are gone immediately.
It's still unbelievable that one connector causes so many error codes.
DevilsJim89
03-15-2019 02:31 PM
flybyglass
03-28-2016 07:05 PM
WesleyCrocket
12-07-2015 01:16 PM
chr1snyc
11-30-2015 12:23 AM
Quick Reply: 03 MDX VTM-4, VSA, CEL on after radiator replacement
