***The Official MDX sign in thread***
#281
Rob n Sonja
If I disconnect the FRONT of drive shaft from transfer, can it be towed without damag
Mid project and have to move a few states over for new Employment. But car is in the pieces at this time. I am going to stuff new motor into k-member assembly and re-install it so the car is one piece and on its own feet. Then I have to tow it about 1100 miles. Car hauler $300, car dolly $50.
❓ finally❓ I have disconnected the rear driveshaft to drop k-member. Thought if I can strap up the driveshaft to undercarriage but still connected to the rear-end and tow it normally on dolly, will the drive shaft spin? Saves allot of money. And One less item on my list,
P.S. everything else is in moving truck already and living in motel until I can get this car ready to transport!
Please, I cannot afford any mistakes or additional damage.
Hubby and mechanic for
Mama Dippie
Mama Dippie
#282
Rob n Sonja
2007 MDX Tech, New Motor and More
Wife's daily driver with 256K miles on it. It slipped 2 teeth on the timing belt and motor went bad fast. So I decided, without ever having done anything bigger than brakes and oil changes to dive in and change the motor myself. Ordered a rebuilt motor with 78K on it. Added new Power Steering Pump, Oil Pump, Both Front CV Axels, New Ultima Red Battery, High Carbon Rotors, Front and rear Motor Mounts, Alternator, Fuel Injectors, Starter, A/C compressor, Water pump, Tensioner and main belt along with Timing belt and tensioner..... Changed out every sensor from; knock, Cam Position, Crank Position, MAP, MAF, all 4 O2's, EGR, Water Temp, Wheel speed, Steering Pressure and Brake Pressure.....Used only the best fluids- everything Lucas brand from Honda power steering fluid to 90w gear oil, Brake Fluid to Tranny Fluid, and Royal Purple Motor Oil. Rebuilt it and fired it for the first time today and she has a terrible knock in the bottom end. I do not know how to diagnose or figure out where it is coming from, and afraid to run engine making that load of a noise, ( i have run it less than 30 seconds at this point ) trying to get codes, only OBD2 codes are 1 O2s sensor and 1 HO2s Heater Errors, and a terrifying message saying major damage could happen if i continue to run engine.
Blacked Out Engine Block and Tranny, Along with all bolt on custom painted Accessories and Custom Wiring Harness.
Blacked out Engine compartment and wire loomed all showing wiring, hoses, and cables.
#283
Rob n Sonja
Username: Harrison Joshua Monteiro
Year: 2015
Model: MDX Tech & entertainment
Miles: 36k
Purchase date: 12-2019
Modifications: None...yet!
Issues(Resolved?): Alot of brake dust on the front wheel (should i be worried?) also looking to increase my knowledge. Since this car has too much tech for me, as my previous car was a humble jeep wrangler with 0 tech
Year: 2015
Miles: 36k
Drilled & Slotted Rotor and carbon fiber / ceramic Pads, Shims and retainers all included
Power Stop, Performance Brake Pads and Rotors Kit K6957 $207 USD (FRONT)
https://www.autozone.com/brakes-and-traction-control/performance-brake-pads-rotors-kit/p/power-stop-performance-brake-pads-rotors-kit-k6957/943678_0_0Power Stop, Performance Brake Pads and Rotors Kit K6953 $172 USD (REAR)
https://www.autozone.com/brakes-and-...953/335300_0_0
#284
New to me purchase
Username: Jeffroe
Year: 2009
Model: MDX Technology
Miles: 105,000
Purchase date: 10/17/21
Avg MPG: 17.6
ModificationsNone
Issues(Resolved?):
Year: 2009
Miles: 105,000
Avg MPG: 17.6
ModificationsNone
Issues(Resolved?):
- Wonky issue with seat memory switch and passenger mirror, seen to be related, as shown in forums hoping to resolve with fix suggested to actuator.
#285
Username: SteveHall
Year: 2011
Model: MDX Tech
Color: Grigio Metallic / Ebony
Miles: 163k
Purchased: May 2023
Fears: Honda/Acura's 2010–2013 J37 oil consumption problem will be the death of this car. (I just finished a 342k mile journey with a 2003 Honda Pilot, so hoping the MDX can get 250k without a lot of investment.)
Year: 2011
Model: MDX Tech
Miles: 163k
Purchased: May 2023
IIDXholic
3G RLX (2013+)
23
10-19-2015 09:40 PM
