OEM ACCESSORIES/ALLOY WHEEL (20") - Need Label.
Old 04-20-2016, 04:27 PM
Martein's Avatar
Somebody please take a photo of placard...
Label on which the recommendations about pressure and other information for the optional 20-inch wheels.
Usually placed in the doorway of the driver's door.
Attached Thumbnails OEM ACCESSORIES/ALLOY WHEEL (20") - Need Label.-1a155a8215cd7c5070390942ccd5d46d.gif
Old 05-13-2016, 12:54 AM
Jsphreal's Avatar
I know this was a little while ago but do you still need the pic?
Old 05-13-2016, 04:22 AM
Martein's Avatar
Yes please
Old 05-13-2016, 02:01 PM
Jsphreal's Avatar
Oh wait I'm so sorry but mine has 19in so idk of mine will have the sticker? You could call the dealer or a dealer with one for sale and ask them to look at the plaquered
Old 05-13-2016, 02:32 PM
Received 16,260 Likes on 11,971 Posts
ZDX optional 20 inch wheel specs:
tire: 275/40R20
air pressure is normally 32-35psi up front
and 32-35psi in the rear
(air pressure is user preference)
it would be nice to know what info you are looking for?
tire size?
air pressure?
wheel specs?
Old 05-19-2016, 02:52 AM
Martein's Avatar
tire: 275/40R20
tire size?
air pressure?
wheel specs?
Me need the 10 character number located on the right side of the new tire pressure label.
Attached Thumbnails OEM ACCESSORIES/ALLOY WHEEL (20") - Need Label.-img_5112.jpg
Old 05-19-2016, 12:41 PM
Jsphreal's Avatar
You can probably call the dealer or just order that sticker from the parts department.
Old 05-20-2016, 08:16 AM
Martein's Avatar
The placard does not have a number, and probably is not sold separately:
OEM Acura ZDX 2010 ALLOY WHEEL (20") parts
I live in Russia and do not speak English, and I can not call?
I would be very grateful if you or someone else will be able to call a dealer and find a number.
Number is needed when set accessories tires:
HDS - > TPMS ->Threshold Rewriting -> Reprogramming for accessory tires:
Attached Thumbnails OEM ACCESSORIES/ALLOY WHEEL (20") - Need Label.-img_5111.jpg
Old 05-20-2016, 08:34 AM
Jsphreal's Avatar
It does have a part number.
OEM Acura ZDX 2010 EMBLEMS - CAUTION LABELS parts
May not be the 20 in option one though. I would call acura
Old 05-20-2016, 08:35 AM
Jsphreal's Avatar
Old 05-20-2016, 09:39 AM
Martein's Avatar
This label for stock wheels, so I have.
But for accessories wheels in complete with wheels and probably has a serial number #8 on a pic:
Old 06-03-2016, 05:07 AM
Martein's Avatar
The Seller of optional wheels from eBay are help me find a placard.
He contacted the dealer, and sent me a photo.
But the placard contains only 5 characters.
Comrades!!! who can call Diller, describe the problem and find out what number me need enter to reprogramming tmps ("threshold rewriting") for accessory tires?!
Attached Thumbnails OEM ACCESSORIES/ALLOY WHEEL (20") - Need Label.-%24_12.jpg
Old 06-04-2016, 08:04 AM
Martein's Avatar
Manual:
INCH-UP TIRE PRESSURE PROGRAMMING
(LOW AIR PRESSURE WARNING THRESHOLD REPROGRAMMING)
1.After doing the sensor ID learning using the HDS, back up to the TPMS Mode Menu, and click on Threshold Rewriting.
2.Select “Reprogramming for accessory tires”.
3.When the HDS says, “Do you want to rewrite the threshold data?” click “YES”.
4.“Please enter the tire information code of new tires” will appear. Click the “Keyboard” icon.
5.Enter the 10-digit tire information code printed on the new tire pressure information label, then click the check icon.
6.Check that the tire pressure shown on HDS, and the new tire pressure on the tire information label are the same, then click “YES”.
7.Check that the current air pressure setting shown on HDS is correct and that the display says “Reprogramming the threshold data for non-standard tires has completed successfully”.
8.After programming, write the tire pressure indicated on the HDS in the service history page for Honda Accessory Wheels, then click the check icon.
9.Aftr programming, sign on the service history page for the Honda Accessory wheels, according to the procedure on page 7.
mossman77
07-27-2016 09:07 AM
Skier4lyfe303
07-05-2016 09:14 AM
tsx_boy
06-17-2016 03:34 PM
CryingMidget
05-25-2016 12:30 PM
Quick Reply: OEM ACCESSORIES/ALLOY WHEEL (20") - Need Label.
