Help - rust on lug nuts! - AcuraZine - Acura Enthusiast Community
LinkBack Thread Tools Search this Thread
Old 01-25-2009, 04:27 PM   #1
Registered Member
Hello,
So, I discovered today that what appears to be a surface rust is starting to form on several of one of my vehicles lugnuts, but primarily on the inside of the wheel lock on each tire. What would be causing this? Is there anything that I can do to remove the rust? It looks terrible!
The car is a 2007 Hyundai Santa Fe Limited. We had this SUV through last winter, so I'm not sure why all of the sudden this started happening. The car did receive it's last oil change/tire rotation at NTB, so I'm not sure if they could have done something incorrectly.
Bottom line, what's the best method to removing this? Is this fairly normal? (I live in Chicago, IL).
Lastly, if this rust cannot be removed, will the dealership replace the lugnuts under factor bumper to bumper warranty?
Thanks much!
Jeff
JLTSX07 is offline   Reply With Quote
Old 01-25-2009, 06:25 PM   #2
Former Sponsor
Metal lug nuts, metal studs......rust.
Remove each wheel, and take a wire brush and remove rust dust from each stud. Cover drum or rotor with a old towel, and spray with WD-40.
Give each lug bolt the same treatment, simply tap on hard surface while upside down, then spray WD in each lug nut. Twist paper towel into each lug nut to absorb excess WD-40, and to remove rust dust. Reinstall each well, and torque nuts to proper rating.
exceldetail is offline   Reply With Quote
Old 01-26-2009, 12:25 AM   #3
Where's my Garage?
PortlandRL's Avatar
Hold the phone there, tiger.
I have a 2004 Santa Fe and I have the chrome plated factory lugs. They are this way because they're exposed (aka the lugs do not have a cover like some cars do). I believe this is a warranty issue so I'd recommend you speak to your dealer about this. I have been all over the Hyundai forums and your issue is the first I've heard of this. I still have the original lugs on mine and no rust; then again living in a state that doesn't use road salt probably helps.
PortlandRL is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Installed on Sport Hybrid: Concept One CS-55 wheels (pics post#6) neuronbob 3G RLX Tires, Wheels & Suspension 19 02-27-2016 11:51 PM
FS: 2nd gen cl PARTOUT. TONS OF MODS! CL-S progression 01 Car Parts for Sale 65 01-26-2016 05:15 PM
FS: 2005 TL $9,850 - Toronto, Ontario (Canada) lanechanger Member Cars for Sale 4 10-13-2015 11:56 AM
How much time do you think I have?? polish_pat 3G TL Problems & Fixes 17 09-30-2015 01:22 PM
Clutch delay valve MilanoRedDashR 3G TL Problems & Fixes 5 09-25-2015 12:04 AM
Tags
40, acura, drum, lug, lugs, mdx, nut, nuts, remove, removing, replace, rust, rusted, studs, wd, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
  • Ask a Question
    Get answers from community experts
What's your question?
Send
