Foam pads "mushrooming "
Old 07-15-2015, 12:50 PM
BenWa03tl's Avatar
Angry Foam pads "mushrooming "
When I'm using flat LC pads they sometimes distort into a "mushroom" shape after a few uses - especially the yellow cutting pads - wonder if I'm applying too much pressure ( backing plate is marked & pad is always still spinning ) or not keeping the pad flat enough? Not changing pads often enough? Looking for input from Jesstzn or one of you guys with experience with this. Am I doing something wrong? Don't want to chew up my pads too fast!!! (Using GG orbital, 5" LC backing plate & 5.5" pads & usually Optimum compounds & polishes by the way )
Old 07-16-2015, 05:38 PM
Jesstzn's Avatar
Most likely too much pressure, should be no more that 15 pounds and kept flat .
BenWa03tl (07-17-2015)
Old 07-19-2015, 07:10 PM
2016 E350 Sport
SweetJazz's Avatar
I agree. Probably too much pressure. I used to experience this years ago when I used a backing plate too small for the pad I was using. Your backing plate diameter and pad diameter are good.
Old 07-21-2015, 08:56 PM
HokieJoe's Avatar
I've detailed for years. I've never used Lake Country, but I have used meguiars, 3m and griots foam pads. After having used meguiars microfiber pads, I will never use foam pads again. They're durable and easier to clean (while detailing) than foam pads imo.
Old 07-28-2015, 03:44 PM
BenWa03tl's Avatar
Still pretty new to polishing but I just tried optimum m/f pads & I liked them - cut well, no deforming & like you said, easier to keep clean. Still trying different combinations to see what works & what doesn't. Still working on technique too
Old 07-30-2015, 07:50 AM
damaged442's Avatar
I primarily use LC CCS pads and at first, I had overheated a few to where they were concave in the middle of the pad. After further experimentation, I actually melted the velcro backing. Lessons learned: clean often, change often, do not use too much pressure.
08_UA7_Gr33k
02-11-2016 02:17 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
2ManyHobbies
09-24-2015 09:23 PM
Quick Reply: Foam pads "mushrooming "
