Wheel Locks ( Recommendations )
Dumped
Right now I'm rolling around w 4 lugs on each wheel but I'm not worried about losing my since they are the factory 5 spoke wheels.
But In case I decide to upgrade, does anybody recommend any wheel locks?
Amazon.com: Gorilla Automotive 38431N Honda Ball Seat Wheel Locks (12mm x 1.50 Thread Size): Automotive
They are good, but OEM ones justnspace mentioned are McGard I believe
Dumped
i've had the mcgard lock shear on me and i've torqued everything to spec
i would only go with gorillas for oem wheels. some of the gorilla systems give you a lock for each lug. i'd recommend the spline locks
There's always this option:
Expensive but the best.
I think they're overkill for stock wheels, though.
RimLox
RimLox
You have to contact for a price quote.
Usually around 400$, which is why I mentioned it probably isn't worth it for stock wheels.
They replace your wheels if they are ever stolen.
if you are ok with running adapters on your stock wheels, a few of us run project mu super lock 7 lug nuts. we of course use them on aftermarket wheels.
all lugs are locks and 7 sided so you need a special key to fit over them. they are also steel and super durable. the only downside is the caps on them are teal so you either have to be ok with that color scheme (i painted my brembos teal to match) or paint the caps something else
single drilled XXR
more like showing my excitement over a single drilled version over the popular multi-drilled version
RimLox
RimLox
If I remember correctly they will even insure your wheels while using their locks. (If you have one of their installers install them of course)
rockyboy
12-06-2022 02:29 PM
1fatcrxnem1
22
06-01-2018 01:23 AM
ahsm
09-09-2015 08:35 AM
braveheart
09-07-2015 08:12 AM
