Whats safer?? Spacer question
2007 Type S WDP 5AT
Is it safer in the rear to run extended ARP studs with a 15mm hubcentric plate spacer? Or is it safer to run a Ichiba v2 15mm hubcentric adapter with built in studs?
I've never heard of either failing, so I don't think it really makes a difference.
I'm running the Ichiba V2 spacers a couple years now and I've had no problems either. If you're getting spacers with built in studs, def go with Ichiba. I've heard of cheap Chinese branded ones braking studs off.
I was too lazy and there was too much work to remove the front studs on my car so that's why I went with Ichiba. Couldn't get the brake dust plate off to change out my studs, hope you guys aren't as unlucky.
if you really think about it....its the same thing...ones not going to be safer than the other....
most people just go with the spacers with built in studs because its easier to install than the extended studs....
just forgo all of that and buy correct spec'd wheels and one wouldnt need spacers!
The following 2 users liked this post by d1sturb3d119:
bluetl04 (03-28-2015),
justnspace (03-26-2015)
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
Eggs999bacon
09-24-2015 10:08 AM
