What tires should I get?
Dont Touch My Car !!!
In for a new set of tires, on my 2nd set of DSW but would like to try something new. These 2 tires are pretty new and have good reviews:
- Hankook Ventus S1 noble2
- Nitto Motivo
Opened to recommendation.
- Nitto Motivo
Hey Tony
Did you mean your were on your second set of Conti DWS?
This is what I ride on and I'm very happy BUT you gave a choice of two tires you are looking at.
I will go for the Hankook due to it's tread pattern look which will look nicer on the car.
Both tires should be good.
nitto motivos are very good tires, i ran them for 15k before i had to go down to a smaller profile.
i now run bridgestone potenza re970 a/s and they are simply amazing. super stiff sidewalls, great traction in rain and dry conditions...i think i'll get these tires from here on out.
Received 6,470 Likes
I'm on my 2nd set of Continental DWS tires....still happy with them.
Hey Tony
Yes, I'm on my 2nd set of Conti DWS tires now and due to some alignment and shock issue causing inner tire wear they need to be replaced they are at 27K. Sucks cause the they still look new with the DSW thread indicator still visible for D=Dry S=Snow W=Wet.
The DSW are good tires especially in wet, I drive 85 MPH when it pouring out at times and I fell glue to the road. Just want to try something different so I can eliminate the idea that I have bad luck with these tires wearing out on the inner thread. I'm going to get A-Spec suspension install soon, so I can start from fresh.
^^^^ Your wear issues have nothing to do with the tire selection.....
you're a moron
"I drive 85 MPH when it pouring out at times "
Putting yourself and other people in danger shows how immature you are.
Hope you don't wrap your car around a tree when you get a new set of tires.
trugem (06-11-2014)
Sorry, didn't mean to come off that way. I probably exaggerated the speed and it is on an interstate.
interstate doesn't make it any better.
Just because others speed in the rain doesn't make it safe.
and yes, I have seen others speeding in the rain and wipe out due to hydroplaning.
im not saying to drive like granny either.
Maybe I get a lot more rain than your region but, when it does people do drive a lot slower.
I've seen folks hydroplane across the interstate even driving at the limit.
Guess since im now a father, I think differently.
Just be safe out there and drive carefully.
sorry for the name calling.
I had a friend that passed away. He was speeding in the rain on the interstate (clearly his fault ) and hit a tree at 90 mph.
joshuae1 (09-16-2014)
Don't worry about it, I understand where you coming from.
Any recommendation on tires?
Did you have these on long enough to drive them in last winters heavy snow? I have been looking at them since I need a new set of tires to replace my Continental DWS. My TL is just a commuter it doesn't get pushed handling wise, looking for something good in rain and snow without having to go to a dedicated snow tire.
#GOBULLS
Yeah, I had driven them in snow a few times last winter. Well I never had the DWS, I can say I felt confident with them in a few inches of snow. Like all other all-season tires they definitely aren't a winter tire. But they were better then most other all-season tires Ive had in the past.
Head a da Family
I've had the Conti DWS's too. What I liked best about them was the ride.
But now, there's only ONE tire. the Michelin Pilot Sport A/S 3's.
The Top rated all season tire in Consumer Reports! To put it bluntly, their words were:
This top rated UHP all-season tire establishes a benchmark in this category.
In other words, the standard by which all other all season tires are judged.
The DWS's aren't even a recommended tire anymore and their snow traction has been downgraded to a solid black circle meaing POOR.
I saw that consumer report too. I wonder how long they drove on the tires. I was reading the other day that due to the usual mfr process tires need to be driven several hundred miles prior to deciding about traction. I don't have a good reference for that info, I've been doing a lot of reading lately. They don't cite their methods of testing for those tires do they? What about Cooper Zeon RS3-A. They were cited as a "best buy" for UHP all season. Anyone have experience with those? I agree with DMZs comment about the standard but the cost is too much for me to bear at this time, I think.
Head a da Family
There are 2 things you just don't scrimp on when it comes to safety. Brakes and Tyiz!
40 million miles of real world experience doesn't lie:
http://www.tirerack.com/tires/survey...jsp?type=UHPAS
sonny@tirerack (09-17-2014)
Stay Out Of the Left Lane
Received 1,236 Likes
No, CR does not release details of how they test. I've had an extensive email exchange with them and got nothing but crap from them. I would totally disregard CR tire reviews and instead rely on the consumer reviews on tirerack.
Tony - you liked the Contis enough to get them a second time, why not a third? The fact that they wore unevenly isn't a fault of the tire based on what you described.
Take a look at this thread regarding the Michelins if you live in an area that gets snow - https://acurazine.com/forums/tires-w.../#post15162956
I tried those for a while. Very average and an overly stiff sidewall, stiffer than tires that have much sharper turn-in and better feel. Mine also started cracking before they were 2 years old.
I agree with the tire rack reviews but make sure you read the ones that have put a good bit of mileage on them. Most tires are decently quiet when new but the noise level can really go up with mileage. My KDW-2 tires were noisy but acceptable when new and by 3,000 miles I could barely carry on a conversation with a passenger and there was no irregular wear. Traction will obviously change with mileage, usually for the better.
We have a set of Continental ExtremeContact DW. They were great when i drove the TL a few times. Probably more grip/performance than my dad notices though. They seem to be working out well.
CostcoFanAUS
09-18-2015 06:05 AM
