Tein Street Advanced Coilover review
Old 08-03-2012, 09:10 AM
  #241
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
You'll probably need to go higher than 600 to get the mirror back...maybe even go buy that MOTHER'S rim ball that Chip Foose is always advertising to finish it off. My guess will be 600 to 1500 to 2500 to final polish and seal.
LOTS OF WORK AHEAD OF YOU, BUDDY.
Why not just prep them and have them powdercoated a cool color?
Old 08-03-2012, 03:05 PM
  #242
Bird is the Word
Predatorbird's Avatar
+1 600 won't give you a mirror finish. You will need to spend most your time on the lower grits and it will get easier the higher you go. After 600, I'd do 1000, 1500, 2000, and maybe 2500-3000 if it's not yet to your liking.
Old 08-08-2012, 02:36 AM
  #243
We Are Venom
sbstnce's Avatar
I pulled the trigger! I just picked these up from a friend who used em for two weeks and decided to sell his tl-s. got them with his ingalls camber kit as well. this thread was the deciding factor so thank you OP. now to install these or take em to a professional. how long should i let them sit at the height i want before i get an alignment. also. if i decide to install spacers will they ruin the alignment. sorry for the noob questions. any help is appreciated! thanks again!
Old 08-08-2012, 10:26 AM
  #244
Nichio's Avatar
I just had my alignment done yesterday after 2 years of having 20mm spacers for flush mount of my type s wheels....my alignment was RECTIFIED ...my Toe was all off. Funny thing is after talking with my alignment guy, the number one issue with tire wear is toe, and if you have a fantastic alignment guy, a camber kit would be damn near pointless (IMO).
I can find a little more to do with $170, like paying for lifetime alignment at Firestone for as long as I own the car for $195... makes more sense due to the roads I live on and theres no limit to the amount of times they'll check. Necessary for those with drops, stretches and pokes.
For the prices we pay for rubber on these, its worth its weight in gold as far as im concerned.
Old 08-08-2012, 12:44 PM
  #245
6SPEED FEVER
EATSLEEPRACE's Avatar
Correct^ If I could go back I would go to a Firestone to have unlimited alignments..toe will kill your tires!...murdered mines in less than two months...I highly suggest you align it right away after you choose the height you want....spacers will change your alignment also...
The more you drive the faster they wear if not aligned
Old 08-08-2012, 01:19 PM
  #246
A spacer (small one) shouldn't affect the steering geometry...Hmmm...
I like the upper camber kits to give that truly flush look where you bring top of tire back out to the fender. Camber won't kill your tires like toe, but at the end of the life of the tire, camber being out will be obvious.
Old 08-29-2012, 12:20 AM
  #247
4DRNSX's Avatar
Just installed my Street Advanced Coilovers today. I set them at the most stiff damper setting because I want that street feel. Do they get more stiff as I go along? I don't want them to be too stiff. I also have the Progress rear sway bar that I'm going to set at max stiffness as well.
Old 08-29-2012, 12:24 AM
  #248
4DRNSX's Avatar
How long does it take for the height to settle?
Old 08-29-2012, 07:19 AM
  #249
I think you're pretty safe with a week or two...
I don't think they get more firm as time goes on...
Old 08-29-2012, 09:09 AM
  #250
6SPEED FEVER
Springs might settle a little after 1month of driving you will notice the difference as for the dampening set as stiff will always stay the same....
Friend of mine has them set at full stiff and he loves it..
Old 08-29-2012, 10:20 AM
  #251
4DRNSX's Avatar
Thanks guys. Yea these Michelin tires are so soft...I want to go for that race car feel but I love the way these tires look What do you guys think about setting the Progress RSB on firm on top of the firmest setting on the Tein's on my Type S?
Old 08-29-2012, 10:50 AM
  #252
Undying Dreams's Avatar
Received 3,824 Likes on 2,847 Posts
Sounds like you're in for a back breaking ride.
Old 08-29-2012, 11:28 AM
  #253
It's manageable...but it's hard to counter such a soft tire...but trust me, once you get that harsh ride you're looking for, you'll wish you had them nice tires back.
Old 09-24-2012, 09:11 PM
  #254
styles109's Avatar
Originally Posted by serbj
Do these coilovers clear the stock front strut bar?
Do you have do drill holes for them to fit like this?
wait what car is that? we dont have to drill any holes for the TEIN SA right?
I just ordered the Steet Advance...
Old 09-25-2012, 02:05 AM
  #255
TL-S
quanaman's Avatar
That is the strut tower bar on the 3g TL.
You don't have to drill holes.
but if you want to be able to access the knobs to adjust the dampening often, you'll want to.
Even then you don't have to but drilling holes makes it a lot easier and faster. If you don't you;ll have to remove the strut bar each time you want to adjust. Not a huge deal either. The holes aren't even visible under engine covers so it wouldn't bother me.
I had mine drilled.
Edit: Still love my Tein SA's. had the rear set to 11 from stiff and front to 10 from stiff. Front was a little too bouncy, so I adjusted it a little firmer, now I'm at 6 from stiff. I'll probably adjust it again and make it 8 from stiff cause now its a little TOO stiff. The back hasn't been adjusted since the install over a month ago.
Perfectionist. ah.
The following 3 users liked this post by quanaman:
Emersont503 (10-03-2012), rockstar143 (09-25-2012), styles109 (09-25-2012)
Old 09-25-2012, 06:40 AM
  #256
I have mine set to almost full soft and even maxed out, 3 years later, I STILL couldn't be happier.
Old 09-25-2012, 03:06 PM
  #257
6SPEED FEVER
No drilling..you set them once and your done!
Old 09-26-2012, 11:13 PM
  #258
Davidsternmustdie's Avatar
I just got my SS advance street and need a edfc controller/motor kit.. what's the model number I need for this? I've looked around and can't seem to find what model number i need for either?
Old 09-27-2012, 10:35 AM
  #259
I think the EDFC is generic for all Tein adjustable rebound coils...all it does is spin the knob up top.
If using EDFC though, you'll need an RV6 strut bar...oem bar won't fit over it.
Old 09-27-2012, 10:57 AM
  #260
I thought I had to buy a certain model edfc and motor kit? Yeah I was aware of the strut bar..the fees keep adding up. Like reading a cell phone bill.
Old 09-27-2012, 02:25 PM
  #261
lleron's Avatar
There are actually a few different models (some more expensive than others for reasons I've never figured out). I believe tein's website has a list of compatible coilovers/EDFCs.
Old 09-27-2012, 03:43 PM
  #262
6SPEED FEVER
UnLess you track and daily drive your car, I see no use for it.....once you set them,most people never touch them again including myself
Old 09-28-2012, 03:59 AM
  #263
styles109's Avatar
Just installed my TEIN SA today. Very happy with this set up. Still need to play with the dampers to get it right for me.
Old 09-28-2012, 06:00 AM
  #264
Yeah, I'd HIGHLY recommend driving around for a week with no front upper sway bar or rear seats...a little stiffer, a little softer...BAM, PERFECT. Then seal it all up and call it a day.
Thanks for the info btw...didn't know there were different EDFC models.
Old 10-02-2012, 07:34 PM
  #265
styles109's Avatar
yeah i have the fronts at 14 and rears at 10. took it to the canyons last night and it felt great! just had tire screeching though. need new rims and tires now
Old 10-02-2012, 08:07 PM
  #266
Deerole's Avatar
For everyone who has these...what setting do you have them on? i think im runnin 12 front n 10 rear
Old 10-02-2012, 09:34 PM
  #267
Tedward's Avatar
I am SO tempted to get a set of these... Really thought I might have the RV6 installed by now but we're still waiting on that end. Strongly thinkin about this being my next project. Any reason from anyone it shouldn't be (minus the $... only thing stopping me )
I don't want to go all the way down (yes, i have read this entire thread end to end and I know it will get to me...), I like the ride of the stock, but could be a little bit stiffer. Seems like a good fit. decisions decisions...
Old 10-02-2012, 09:35 PM
  #268
...I'm something similar to that.
Old 10-14-2012, 08:41 AM
  #269
KJ TL-S's Avatar
Old 10-14-2012, 10:46 AM
  #270
sockr1's Avatar
Received 1,158 Likes on 909 Posts
How long do these coil overs typically last before you have to rebuild them? Trying to decide between h&r sport springs and then getting new shocks in 30k miles (currently at 55k), or just go coilovers now. Leaning towards much cheaper springs since I will only lower less than 1.5 "
Old 10-14-2012, 02:35 PM
  #271
6SPEED FEVER
They last a very long time,guys gave gone upto 70k miles!
In my opinion, do it right and only once, your throwing your money away by using springs with stock shocks then paying again to replace the shocks....it's actually better just to do the coilovers in the end...
I started with a set of springs and sport shocks and was ok with it but never happy...
I said the same thing about only dropping -1.5 and now I'm almost twice that!.....with springs the way it settles that's the way it's going to stay!
Old 10-14-2012, 03:19 PM
  #272
KJ TL-S's Avatar
Thanks for the review eat....glad to hear they will last too. That was another reason I wanted these and not a cheaper option.
Old 10-15-2012, 01:00 PM
  #273
Former Sponsor
Excelerate's Avatar
TEIN coilovers will last generally from 60-90k before needing a rebuild. I would venture to say they are one, if not, of the best quality coilovers on the market. And they are reasonably priced. If you're looking for an entry level coilover I'd recommend the TEIN Street Basis.
http://store.excelerateperformance.c.../i-512847.aspx
Old 10-15-2012, 01:06 PM
  #274
KJ TL-S's Avatar
^^^Thanks, good info here.
Old 10-15-2012, 01:29 PM
  #275
sockr1's Avatar
Thanks for the info, very helpful!
When tein SA advertises F/R as 1.7, I'm assuming that is the ideal lowering height. Is there any downside to lowering less, such as 1.5? Or are springs the way to go if I don't plan on changing height once set?
Old 10-16-2012, 11:40 AM
  #276
Former Sponsor
Excelerate's Avatar
Correct, that is what they recommend. You can basically go from 1-3" on this setup so any height in that range is fine.
Old 10-16-2012, 04:20 PM
  #277
emilio320's Avatar
hmm so 60k-90-k miles means ill probably need to rebuild mine around 90k-130k miles on my car.. Anybody know how much it costs to have them rebuilt by tein? Its a good thing i haven't sold my stock Type-S suspension yet, that way i can throw them on while i get the Teins rebuilt (whenever that happens)
Old 10-17-2012, 10:56 AM
  #278
it depends on conditions, how low you are, how hard you are on them...lots of factors. And as with anything mass produced, there will be some anomalies that last much longer than others...
Ride em till they're dead, then figure out if you want new ones or rebuild. I think it's close to $400 for rebuilds. could be wrong though.
Old 10-17-2012, 11:03 AM
  #279
sockr1's Avatar
Probably a stupid question but how do you know when they are dead? Noise, visual, bouncing?
Old 10-17-2012, 11:18 AM
  #280
Former Sponsor
Excelerate's Avatar
See this link:
http://www.tein.com/service/index.html
Suspension get bouncy and soft. The dampers may eventually start to leak.
sockr1 (10-17-2012)
Quick Reply: Tein Street Advanced Coilover review
