Tein Street Advanced Coilover review
So I purchased these coilovers and finally got around installing them today. This is my third suspension I have installed on a TL,so I have experienced the good and the ok.
These coilovers are the best suspension I have ever had,the way my car handles overall impressed me. Im very happy that I'm at the drop I would like and my car drives really smooth.
I can confirm that the tein street advanced would stomp f&f coilovers. The built quality is way better. For example, the wrenches are built better and are way more easy to adjust,thicker rubber dust boots. It is just more solid Coilover.
Of coarse downside is it does not come with top hats,but you can use ure old ones or buy new ones. I bought new ones because I'm anal like that ,only spent a little over 100 bucks,very worth it.
The dampening adjustment was a breeze,I set it once drove it around the block and was in love...lol......I set it at 10 clicks from stick in the rear and 11 from stiff in the front. Handling is great while still maintaining a smooth ride.
The following 4 users liked this post by EATSLEEPRACE:
Ive had the function&form coilovers version 2 type 1(least favorite at any height,ride was horribly stiff.......I've had tokico/h&r sport (nice setup but not as low as I wanted)......I've taken a ride in d2 coilovers with dampening(felt just like f&f coilovers) and was not impressed.
I think
I think
JD TL-S (05-23-2012)
Out of the box is random.....but the manual tells you the height to set it at which is one inch collar gap.....I did 1inch collar gap in the rear and a little less Front.....yes I was able to adjusted with them on as when I set both at 1 inch ,I lowered the front a little more....I had access to a lift at a shop so it was a breeze and the wrenches it brings are made of good quality..it was a pain in the ass when I had the function&form
sams24 (12-21-2013)
Proud owner of a...
OP, I have a question for you: do you think it is worth the money to get Street Advance+EDFC rather than just a set of Street Basis?
I don't care about high or low or comfortable or not. I only want my car to drive like a true road-going WRC race car. Inaccurate has stressed a lot about the importance of getting adjustable damping, so the coilovers can be truly stiff. However, for Tein, at least, that means additional $600.
If you want a true stiff Coilover,why don't you try out the new xlr8 isc coilovers,you can get the race spring rates plus it has dampening adjustment. That company is very popular on performance cars like the Evo and STI.....in my opinion all basic coilovers are stiff,if you want best of both worlds why not try tein,you want more performance isc is a good choice because they offer custom spring rates.
Thanks for the review. Still wasn't sure if i should get these or the ss but it looks like the advance are a better deal. Do you mind if i ask where you got them from?
N0w $hiftinG N/A
car looks nice bro wish I would of new you when I was living in nyc a few months ago lol.I was actually debating on purchasing these coilovers over htspec2 but went with the spec 2 just because I didnt want to buy new or re use the old tophats.
Bought mines from heeltoe..after the coupOn code you can't go wrong,knowbody sells them cheaper from what I see plus they were shipped out next business day....Still waiting on my camber kit though...lol
Bought my top hats my top hats from Oem Acura parts plus you get 5%off on top of their prices are already low......
**i have a type s but bought everything for a base to maximazie comfort...
Proud owner of a...
The bushings are different and some washers you don't you with a type s...but the mounting base are the same....I can post part numbers if you need them....I also like that there is a video from heeltoe on how to put it together NO COMPRESING!!!..with the base bushings of coarse
JD TL-S (04-08-2012)
rocking my vs-sexx!!!
me too just got mine installed the hype is true..i haven't mess with the dampening yet i think I'm on stiff on all 4 it rides really good.
i still need to mess with the height and dampening.
https://acurazine.com/forums/car-parts-sale-361/19-rays-forged-g35-wheels-tires-852940/
The following 6 users liked this post by EATSLEEPRACE:
demon-cleaner (05-19-2013),
JD TL-S (04-09-2012),
LeMix (05-14-2013),
MEKO (05-22-2013),
Paparomeo (04-05-2016),
and 1 others liked this post.
Proud owner of a...
BASE TOPHATS
PART NUMBER:. QUANTITY:
51621-S84-A01 4
51631-SV7-004 8
51728-SR0-003 4
51675-SEP-A03 2
51685-SH3-014 8
51686-SDA-A01 2
51689-SH3-004 4
52690-SG0-000 2
52686-SDA-A01 2
52675-SEP-A02 2
Video on how to assemble:
http://www.youtube.com/watch?v=oG3tUjPbcc8
51621-S84-A01 4
51631-SV7-004 8
51728-SR0-003 4
51675-SEP-A03 2
51685-SH3-014 8
51686-SDA-A01 2
51689-SH3-004 4
52690-SG0-000 2
52686-SDA-A01 2
52675-SEP-A02 2
So, if I want to get Type-S top hats for my base TL, I should get the following parts, correct? Mine is a 2005 base 5AT TL.
Part number: Description: Qty:
51621-S84-A01 WASHER, SHOCK ABSORBER MOUNTING x4
51631-SEP-A01 RUBBER, FR. SHOCK ABSORBER MOUNTING x8
(^This part is different between base and Type-S)
51728-SR0-003 COLLAR, SHOCK ABSORBER MOUNTING x4
51675-SEP-A03 BASE, FR. SHOCK ABSORBER MOUNTING x2
51685-SH3-014 PLATE, DUST COVER (SHOWA) x8
51686-SDA-A01 RUBBER, FR. SPRING MOUNTING x2
51689-SH3-004 PLATE, BUMP STOP (SHOWA) x4
52690-SG0-000 PLATE, BUMP STOP x2
52686-SDA-A01 RUBBER, RR. SPRING MOUNTING x2
52675-SEP-A02 BASE, RR. SHOCK ABSORBER MOUNTING x2
________________
In addiction, shouldn't I also get (shock absorbers') flange nuts?
Yes yes yes!!!!
I bought the TEIN Advance coilovers, Progress adjustable rear sway bar, and the ingalls camber kits from EXCELEREATE PERFORMANCE. That guy knows his stuff. Parts got here within 3 business days. This setup is INCREDIBLE!!! I had the car corner weighted and balanced for my body weight by Gran Turismo East. Since I retained the OEM front sway bar the rear was set to the softer setting. All the dampners were set to 3 clicks away from full firm. The front has one finger of gap and the rear has two fingers of gap in case I ever have a full car. The car is raked just like a ferrari I compared it today when one happened to pull up next to me.
Everything feels outstanding to the point that I want to take the car to Road Atlanta and do a track day in it. No more wheel hop either. You can feel the car start to spin a touch in third and then grab and launch forward. I only felt stuff like that in my WRX prior to this car. Definitley have the school girl giggle.
baynham (11-14-2012)
No nut as the coilovers bring some!.....
***i wanted to purchase from excellerate because he is closer to me but Marcus from heeltoe,has more affordable prices
Drop it a little lower,still have same dampening settings from the beginning..
I also bought all new top hats at Acura when I installed Tein SS coilovers in the spring of 2009 on my 06 TL 6-speed.
I am buying a Type-S soon and want the parts list for top hats so I can just take the OEM Type-S coilovers out and install Tein"s without having to rent a spring compressor. Also easy to switch back if needed.
Are these Tein's you bougth the New Version of the Tein SS coilovers ?
Thankyou
Proud owner of a...
Please do
Thankyou
Thankyou
Do you have do drill holes for them to fit like this?
Yes these are the new version of tein....these are better than the ss, 200% plus dampening adjustment over the tein ss!......that means they can be adjusted twice as soft or hard as the ss.......
Type s TOPHATS part numbers are on post #30
I refuse to drill any hole on my bar....it's looks tacky....once you set it to your liking..you won't touch it again....if you are a person that goes to the track often and drives street also than you might want to consider EDFC,other than that dont waste your time or money
Mine are set 11 clicks from stiff in from and 10 clicks from stiff in the rear..start from there,you wil love it ...it's stiffer than oem type s!!! But smoother!...make sense?
That's why I say get the base bushings you won't be able to tell the difference.....
Check this out...I work on my car in my friends shop because it's just way easier when u have a lift..after I lowered it a little more ,I took him for a ride,we went to grab lunch...and he brought it up on how low my car is and still drives so smooth ..
And this guy is like an anti- Coilover person...he believes Coilovers just needs up the ride on a car like ours
Awesome EATS
I was just on Ebay and they still sell the Tein SS coilovers for over $1000.
Thanks for the Marcus Video.
I also bougth all the top hat parts back in 09 for my 06 TL manual.
I thnk this time I will order from Heeltoe (Marcus) and get all the top hats and parts from him also. Another $200. Easier then explaining to Acura Parts guy, and only $50 more from Marcus.
I will order a set in early July
Thanks again EATS
Thanks again EATS
