Softer Suspension
Softer Suspension
Quick introduction:
- Lives in Wisconsin
- Not very mechanical handy
- Having really bad back pain issues lately
- 07 TL Type-S with Type S suspension
Doesn't care about the height anymore, I need the most comfortable suspension.
What should I get?
Where can I possibility get it installed?
Looking to switch the suspensions back once back issue is resolved.
Thanks everyone
What should I get?
Thanks everyone
vincenttheboy (07-24-2015)
How long is your back situation going to linger on for?
Honestly, you have a better shot at borrowing someone's car/trading it with a friend or family who has a softer cruiser, then swapping when your back is good if possible. Saves you money and headaches. Most off the shelf springs and coilover units usually go towards stiffening the ride, unless you want to pay up for pricier units that could make your car a "tad" softer, but floaty and handle worse.
Or use public transportation.
^ thats a great idea.
Easiest thing to do on your car is change the tires from low profile to a taller side wall tires. A touring type of tire would be best for comfort. Just go talk to a tire shop for recommendations.
justnspace (07-27-2015)
Another thing that will really help with the ride is the tire selection, size, and amount of air in it. Your stock OD is 25.5", you could move to a 26" OD like I did, and run 29/30 psi and get a much smoother ride. If you need some help with this, just PM me, I'd be happy to help you out.
The following 2 users liked this post by VisualEchos:
ExcelerateRep (07-27-2015),
Former Sponsor
Your best bet for a comfort oriented suspension is getting oem springs and something like the KYB GR-2 gas shocks that are designed for comfort. As VisualEchos mentioned you could try going with a wheel that has more sidewall. Other than that, most aftermarket options will stiffen up the ride.
MrHeeltoe
20
02-23-2023 01:54 PM
neuronbob
23
07-16-2019 10:48 AM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
