Oh no-not this camber post again.
Old 10-24-2012, 01:37 AM
KidJdm's Avatar
Question Oh no-not this camber post again.
So i just got my coilovers, and i was wondering will i need camber kit for the rear for a 2"inch drop? I been reading around the forums, and would it be smart to just drop it first than get wheel alignment, then figure if i need camber kit? then getting another wheel alignment? again sorry for this post about camber i been really confuse :/ thankss
Old 10-24-2012, 04:28 PM
Undying Dreams's Avatar
Received 3,824 Likes on 2,847 Posts
Depends on how much camber you're running. The main you thing you want corrected is toe. It will eat a tire like crazy. People here run -3 (camber) in the rear and have no problems.
I myself am at -2.5 in the rear with a 2" drop. I just lowered some more over the weekend and I'll be getting another alignment soon.
It's kind of a preference, I myself will be getting a rear camber kit.
KidJdm (10-24-2012)
Old 10-24-2012, 06:16 PM
HE>i
05_NBP_TL's Avatar
With coilovers, and going 2" drop, I would go ahead and install the camber kit at the same time. That way when you get your alignment you can be done in one trip.
If you wait till you get your alignment first, then need a camber kit then you could have almost bought the camber kit to start off with.
Two alignments will cost more than a camber kit. I installed all my suspension at once (coils, camber kit, rolled fenders) so I was done after getting an alignment. no more second trips or worn tires till I got the parts needed.
KidJdm (10-24-2012)
Old 10-24-2012, 07:02 PM
KidJdm's Avatar
what if i have function form 2, with camber plate adjustment. how does that work?
Old 10-24-2012, 09:22 PM
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
when your camber is more than your drop, you are doing it wrong
05_NBP_TL (10-25-2012)
Old 10-25-2012, 12:00 PM
CLtotheTL32's Avatar
Received 9,495 Likes on 6,167 Posts
Anil
OP I would get a camber kit. I'm only dropped on springs and I got a rear kit and I'm considering getting adjustable ball joints for the front. I would rather pay $150 or so to correct the camber than ruin tires.
Old 10-25-2012, 01:41 PM
Former Sponsor
Excelerate's Avatar
The 3G TL has a lot of negative camber/toe issues when being lowered. There's a fair amount of negative camber from the factory in the rear.
I'd recommend the INGALLS rear kits (qty of 2 needed):
http://store.excelerateperformance.c...5/i-60220.aspx
urbtsx
03-04-2017 06:53 PM
o8 ENVII 8o
11-30-2015 04:23 PM
Robospinner
22
09-24-2015 08:47 AM
funkbro2
09-21-2015 07:53 PM
Quick Reply: Oh no-not this camber post again.
