Need Clarification on rims
Old 12-19-2014, 08:36 AM
4DGSR's Avatar
Hello -
I recently bought a used 2005 6MT TL and need clarification on the problem I will run into with the factory brembo's up front....
Are people running into the issue that the face of the wheel is hitting / rubbing on the caliper? Or is it that some manufacturers of aftermarket rims inner diameter of the rim hitting / rubbing on the caliper?
I know that the factory TL rims are:
17x8 +45 with 235 45 17 tires.
I wanted to stick with the 17" diameter but go with a set up like this...
17x9 +35 with 235 45 17 tires.
Where I live, the roads are not forgiving and I don't really want to go 18". I am currently stock height but plan on lowering it with either H&R springs or a full coilover set since the car does have 115k and I am not sure if the factory shocks have ever been changed.
I was looking at these...
Thanks for the help!
Old 12-21-2014, 11:13 PM
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
I thought factory rims were 42? Either way, pretty sure you'll need ~5mm spacers for that proposed set up. Use the sticky thread to check your options, that's what it's there for.
Old 12-22-2014, 04:02 AM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
Factory rims are indeed +45
Old 12-22-2014, 04:47 PM
04 Acura TL
shotta's Avatar
I would go with Vordoven 18x9.5 +22 with 225 40 18 but you should be ok with 17x9 +35 if it doesnt fit you can use a 5mm spacers
kev87a
11-02-2015 07:40 AM
Gout
11-02-2015 12:22 AM
kev87a
10-18-2015 02:03 AM
dirleton
20
10-16-2015 01:48 PM
Quick Reply: Need Clarification on rims
