Help! Koni yellow and Type-S bushings.
Old 10-28-2011, 06:57 PM
Received 16,260 Likes on 11,971 Posts
I'm doing it wrong.
I went to my friends shop, with a spring compressor, to take off the top hats from the OEM shocks.
the metal sleeve that fits inside the bushings wont fit over the koni yellow threads.
sorry for the poor quality
what am I doing wrong?
the part number for the shock is 8041 1332L which I think is correct.
Old 10-28-2011, 07:13 PM
And even then, the type-s bushing has a steel outer layer. it wont go through the threads.
Old 10-28-2011, 07:26 PM
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
That steel collar is used on virtually every Acura ever made - exact same part for years and years and years.
IIRC, when we did mmade22's, we assembled the tophats, put the dust covers, washer, etc., on and then just slid the tophat on and tightened it up. No problem.
So I am thoroughly confused why that collar doesn't fit.
Also, pics of the "Steel outer layer" on the Type-S bushing?? I don't remember that either.
Old 10-28-2011, 07:29 PM
unfortunately, I left most of the parts at the shop.
I only took the Left front shock and 1 of the type-s bushing, along with 2 oem bushings.
will get pics up.
Old 10-28-2011, 08:04 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
I heard that people had to "expand the metal collar".
You should be able to separate the collar IIRC to expand it.
Good luck!
Old 10-28-2011, 09:13 PM
^nice!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!! it is expandable....its has a slit down the middle.
I FUCKING LOVE YOU.
now, I have to figure out the type-s bushing. the steel top part will not go over the threads, if i force it, it will fuck up the threads.
Old 10-28-2011, 09:24 PM
Underside
on the LEFT is the type-s, and on the right is the OEM
top side
again the left is the type-s. you can clearly see that the diameter IS SMALLER.
it is also some sort of metal. if i drop it on my tile, the tile would crack.
Old 10-28-2011, 09:25 PM
by the way, GP, your sig makes me want to click the arrows.
CLtotheTL32 (10-28-2011)
Old 10-28-2011, 09:39 PM
I'm an idiot and forgot about the flash on my camera.
same images, only with flash.
I scratched the metal to show it is metal.
Old 10-28-2011, 10:06 PM
AZ Community Team
Bearcat94's Avatar
Put it in a vise and ream it to fit?
Old 10-28-2011, 10:22 PM
#1 Super Guy!
94eg!'s Avatar
Okay here is the deal. Yes the shaft diameter is larger where the top-hats mount on Konis. They have always been this way. The shocks should have included new larger diameter sleeves and washers (no bushings). You will need to use the sleeves from the Koni kit and toss the washers. If you did not get the sleeves in your kit, contact Koni for replacments.
Now whenever Honda makes a performance version of a car, they always use this special style of top-hat bushing. They are found on the Integra Type-R, Civic SIR, the S2000 and now the TL Type-S. Because these bushings have integrated washers inside the rubber, it is necessary to drill out the hole in the bushing to make room for the larger diameter shock shaft. This is common issue in the Type R forum on Honda-Tech.
If you look at the captions in the following link, you will see what I mean:
http://www.k-series.com/tech_document.php?id=8
Before and after:
Old 10-28-2011, 10:28 PM
Fucking awesome!!!!!
my kit did come with the new larger sleeve/collar.
I just was in a rush because the shop was closing and didnt put two and two together.
Thanks!!!!
i love you 94EG!
Old 10-28-2011, 10:47 PM
#1 Super Guy!
94eg!'s Avatar
Nevermind my comment about the sleeves. I missed that part of your thread.
Old 10-29-2011, 01:14 AM
KingKong_Dav
kingkong_dav's Avatar
i know a quick solution to ur ordeal. you have to buy type s shocks. haha that is funny you fcked up this bad. dont be sooo excited with the type s bushing it doesnt do much. ive done this on aspec top hats and switch back the next day because of poor ride quality. lol your funny
Old 10-29-2011, 07:42 AM
Thanks for your suggestion kingkongfag.Only the one you proposed would take even longer than the solution founded in this thread.
Also, you can see in the pictures the difference between the type-s bushings.
Old 10-29-2011, 08:40 AM
Chapter Leader (Houston)
TLDude876's Avatar
Received 1,085 Likes on 810 Posts
^ Good luck with it today Justin!
Old 10-29-2011, 09:54 AM
Good luck with the install!
I'm working on mine today too.
I just found out that my A-Spec rears have Type-S bushings on them still!
I can tell the top of the bushing is metal when I tap on it with my finger.
That makes my fronts-stock bushings,rears-type s bushings
I wonder how that's gonna ride lol
Old 10-29-2011, 10:22 AM
Thanks Dennis! Thanks GP!!
Old 10-29-2011, 10:46 AM
Hopefully 94eg! sees this.
How to know off the mounting brackets for full travel!?!?!??!?!
Old 10-29-2011, 11:33 AM
#1 Super Guy!
94eg!'s Avatar
I'm sorry I didn't get your question.
I have seen where people mount their front shocks lower in the damper fork, but that was on older Civics & Integras. I don't know if that's doable with this car. I don't think you should worry about this unless your going to be slammed really low anyways. A typical lowering spring will be stiff enough for it's drop without messing with shock travel. Besides, you can run into new problems by increasing bump travel. Things like your UCAs banging against the inside of the fender is common. Especially if you have a front camber kit.
As far as I know this is new territory on the TL. You probably don't want to be a guinea pig.
Old 10-29-2011, 11:59 AM
Originally Posted by ihc
This is super simple. All you do is knock the locating tab off of the bottom of the shock body (the tab that stops the shock from sliding too far into the mount). Make sure to mark the where the bottom of the tab is so you have a reference (in case the missing paint is not enough lol). This tab is only there to locate the shock at the right height for installation, it has no load bearing capabilities so there are no worries about the shock slipping in the lower control arm with it removed.
The goal is to install with the spring perch in the highest position which will give you the additional travel. Ride height adjustments are made by sliding the shock further into the lower mount.
It make a huge difference especially when hitting bumps while cornering hard. The car will be much more planted. The ride will be improved as well since you will be hitting the bumpstops less.
IHC sent me a PM.
I believe he has done it. and I remember a thread where you and him were discussing this.
since I have no ride to take me to the shop, yet...I've been trying to knock off the tab.
i cant break the welds
Old 10-29-2011, 12:09 PM
^oh and no wonder why you couldnt understand my question....
I meant knock, not 'know'
Old 10-29-2011, 03:35 PM
#1 Super Guy!
94eg!'s Avatar
You could give it a try, but you need to test fit everything without the spring in place to make sure you've got the shocks high enough that the drive-shafts won't contact the shock body anywhere in the suspension stroke. You also want to make sure the UCAs won't hit the shock tower. Also make sure you get both left & right shocks in exactly the same position. If you have the patience to do this, then go for it.
Of course knocking spot welds of a shock body sounds like a PITA to me.
You know you could always go back and do this later if you want. Just remember you need an alignment every time you replace suspension parts or change your ride height.
Old 10-29-2011, 07:29 PM
-------Tim-------
Slpr04UA6's Avatar
If I remember correctly u will have to drill out the type-s bushings to 12mm. I had Marcus drill mine out when I ordered them. Also when you are using the type-s bushings you will eliminate some of the hardware from the stock setup. This being the metal collar that u referred to earlier in the thread(again if I remember correctly) and some of the washers as well. Also you will have to drill out the bumpstops as well (to 12mm) in order for them to fit over the Koni's, I cut mine as well. I will try to find the emails that I have some of the info I have from when I did mine, if I have it. Lol!
Old 10-29-2011, 10:52 PM
#1 Super Guy!
94eg!'s Avatar
Bump stops don't need to be drilled. The stock shock shafts are 12mm where they sit. It's the stock shafts that tapper to 10mm where the top hats and bushings bolt on.
Old 10-31-2011, 03:15 PM
Former Sponsor
Excelerate's Avatar
We've done this install few times before. You have to drill out everything to accommodate the larger shaft of the KONI shock: washers, bump stops, etc
Old 11-05-2011, 08:14 AM
So, I've had my car on jack stands all week. Yesterday, I had the day off and tried to complete my install.
Went back to my friends shop with a drill to drill out the bushings.
What kind of shop doesnt have a drill? lol I know.
anyway, I had found a drill at my house. You have to understand, this drill is from the 1930's. well, not really. but its freaking old.
I got to the shop plugged in the power drill and it wouldnt work. God did not want me to finish up this install at all.
Went to a shop down the street to have them drill out the bushings.
came back to my friends shop and used the spring compressor.
Voila!
Front:
You can see where I tried to knock off the mounting tab.
Like 94eg! said; that spot weld is pretty tough.
Rear:
My silly ass forgot to install the dust boot covers and the dust boot shield thing.
I'll fab up a shield boot thingy using the oem one.
Brb guys, I'm off to install them on my car.
Btw, I paired the aspec springs with the koni yellows and type-s bushings.
Old 11-05-2011, 08:56 AM
AZ Community Team
Bearcat94's Avatar
I thought you were doing (already had?) H&R Sport springs?
Old 11-05-2011, 09:01 AM
^the sale fell through.
plus, when researching H&R did not disclose their spring rates. I had no idea if the front were stiffer than the rears. from what I understand, you want the rears to be stiffer so it can induce oversteer. is this right?
then my buddy gave me the aspec springs.
TLDude876's Avatar
neeeed moooooarrrrr lowwwwww Hope you get it done today man
Old 11-05-2011, 09:05 AM
thanks Dennis! When ever mani wakes his ass up to help me!
Old 11-05-2011, 09:15 AM
AZ Community Team
Bearcat94's Avatar
http://www.tirerack.com/tires/tirete....jsp?techid=58
Gave? Hard to beat free.
Old 11-05-2011, 09:22 AM
yes, I'm on my way to being the track king.
*edit* I also have the progress RSB set at stiff
yes, free!
Old 11-05-2011, 09:26 AM
TLDude876's Avatar
^ Get the car running and come over by the car show @ Fry's
Old 11-05-2011, 09:28 AM
AZ Track Whore
vill0169's Avatar
yes, free!
THEE TRACK KING?!?!?!?!?gonna have to earn that one bro! hahaha get that car back together and drive that thing.
Old 11-05-2011, 09:30 AM
okay, okay. rex, you know you're the track king.
Old 11-05-2011, 09:48 AM
I are LEGEND's Avatar
Glad you sorted through everything. Should have let me know sooner, I would have driven down to help you out.
Old 11-05-2011, 10:28 AM
AZ Track Whore
vill0169's Avatar
Well what's better than one TL on track? that's right, TWO TL's on track
Old 11-05-2011, 10:33 AM
damn i wished I had koni yellows haha
I'm gonna work on my front passenger suspension today, getting the broken pinch bolt out!
Old 11-05-2011, 10:55 AM
Now, would it hurt if I didnt install the dust covers?
I dont want my knoni's to seize. ahhhh
Quick Reply: Help! Koni yellow and Type-S bushings.
