Best tire size for 18 x 8.5 with +35 offset rims on an 04' TL Base?
Old 08-02-2015, 10:47 PM
josh77r's Avatar
Purchasing Varrstoen ES111 in 18 x 8.5 for my TL in the near future. What tire size would keep the speedometer from being off? And also keep the tires from rubbing anything?
Old 08-02-2015, 10:50 PM
josh77r's Avatar
Old 08-02-2015, 11:29 PM
Andrew
VisualEchos's Avatar
What's the offset of the wheels? That makes a difference. And do you plan to slam the car? Do you like the beefy tire look?
My 255's would be square on 8.5, have less than 9,000 miles on them, and are for sale.
BC3 by Andrew Thompson, on Flickr
bluetl04 (03-26-2022)
Old 08-02-2015, 11:42 PM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
235/40VR18 Yokohama AVS ES100 tires are what Acura put on their 8.5" wide A-Specs. I'd go with that size if you want the most accurate speedometer.
Old 08-02-2015, 11:47 PM
Andrew
Tire sizes aren't standardized, so not all 235/40's will be 25.5" OD, nor do they need to be. 25.3-25.7" will give you no error worse than factory. My tires are 26" even, and cause at worst a 2 mph difference at 75 mph.
Old 08-02-2015, 11:52 PM
josh77r's Avatar
Is your car lowered at all? I love the look.
Old 08-02-2015, 11:55 PM
Andrew
Yeah, it's lowered, just recently. Here's a shot with the wheels/tires just bolted on with no drop.
Summer. by Andrew Thompson, on Flickr
Old 08-02-2015, 11:57 PM
Andrew
My goal was to make the car appear more beefy, so I got the 255. I chose the 40 sidewall because I wanted the car to appear slightly lowered, even though it wasn't, and to give me a bit softer ride, which it did.
Old 08-03-2015, 12:09 AM
Andrew
You can kinda' see on my tires where they are "soft" or "round" on the top and bottom edges. This is because I have a 9.5" wide wheel, which really needs a 265 tire. My same 255 on an 8.5 or 9" wheel would fit better, and be more square. With the +35 you'll be running, you could use the following sizes...
235/40 (generally 25.5" OD)
245/40 (generally 25.7" OD)
255/40 (generally 26" OD)
It really depends on the look you want.
Old 08-03-2015, 12:28 AM
Not arguing with you. You just proved my point. It's up to you. If you don't care about an accurate speedometer you can run whatever size tire you want.
Old 08-03-2015, 07:29 AM
Andrew
I'm not arguing with you either, I'm just saying that I've seen the variance between the same size tires produced by different manufacturers be larger than the variance between different sizes. So, getting caught up in installing an tire that's exactly 25.5" tall is really useless. Truth be told, his speedo is probably off as it is .
Old 02-13-2022, 09:16 AM
3rd Gear
Tajaun Fulford's Avatar
I have a 3rd gen tl on lowering springs trying to find wheels I saw comis racing Mrii +15 will they fit if I went for a 255/35/18? I wouldn’t mind rolling fenders but it’s the case of excessive poke if it’s like a few millimeters that’s fine but not 1inch poke
GhostTL09
09-19-2015 01:57 PM
Hau_nguyen91
09-06-2015 12:53 PM
nuldabz
09-03-2015 05:49 PM
bailey24
08-31-2015 05:38 PM
Quick Reply: Best tire size for 18 x 8.5 with +35 offset rims on an 04' TL Base?
