Adjusting Koni's is a PIA
Old 09-26-2015, 07:29 AM
lowgrowl's Avatar
To adjust them requires removing the front strut brace and the rear seats. I think I can remove the brace myself but the rear seats I don't want to attempt. Is it possible to drill some sort of hole in the back so I can easily access them for adjustment ?
Old 09-26-2015, 03:14 PM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
rear seats arent that hard....take about 10 minutes once you get used to it, you'll also want to remove the C pillars and slightly lift the rear deck to properly get the adjustment knob on and turn it accurately. I do this every once in awhile, doesn't take more than 30 min from start to finish for everything.
Old 09-26-2015, 05:18 PM
csmeance's Avatar
Received 1,988 Likes on 1,412 Posts
Get a new strut brace with the holes cut out so it's easier to access. Rv6 makes a great one.
For the rear, you can cut a small access flap in the rear deck cover but it won't look good. You can buy these little extensions for the tein shocks but I have no clue if they work with the konis.
Mike734
12-10-2021 01:25 PM
TL14
09-24-2015 04:37 PM
flybyglass
09-24-2015 01:12 PM
Quick Reply: Adjusting Koni's is a PIA
