Lowered RL How to adjust auto leveling headlight sensor
Hey guys
Not sure if anyone has done this when they are lowering there RL .
But if you have a set of H&R springs the rear tilt sensor will have to be adjusted. I noticed my headlights being off while driving after my drop.
So i adjusted the tilt sensor 6 turns out and i picked up 3/8" of healight height just over 3 feet away.
before you lower the car when its sitting on the ground mark the pointer on the tilte sensor body or raise the car up to the stock height. Then Just mark the shaft and mark the use a 10mm and 11mm wrench and loosen the jam nuts. Becareful not to twist the ends to much. takes about 5.5 to 6 turns and i was at the OEM position.
rockyboy
12-06-2022 02:29 PM
cycdaniel
12-17-2019 10:58 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
