Wheel Fitment 19x8.5 32mm
Hi I recently purchase 2012 acura tl and wanted to upgrade my wheels and suspension . I am looking into BBS XA 19x8.5 32+. Can you please confirm if it fits ? I am also looking to drop with Tein SA about 1.5 inch .I wanted to go with 20s but roads here in NJ are horrible . These are my options:
BBS XA0103BPK, BBS XA Series Wheels | BBS
If i decide to go with 20's .. i will look into forged option : 20x10 40+
https://www.elementwheels.com/prodde...d=rwrf12010blk
The Original Shawdy
19x8.5 +35 will fit just fine. 20x10 +40 will also fit but you're gonna have to roll the fenders if you're planning to lower your TL.
No one is running any of the 3 wheels .. So i am not sure how it looks and how the fitment is ? and i really dont know the quality of the wheels . Even though 2 of them are forged .
The Original Shawdy
Not gonna rub with rolled fenders. I'm running 20x9 +16 front with no rub or roll. 20x10.5 +25 in the rear, no rub with rears rolled flat.
All comes down to ride height, tire size and camber. Check the wheel specs and picture thread for fitment ideas.
Can't speak for those wheel brands on quality.
5th Gear
I test fit my 18x9+22 Varrstoen Es7 on my stock 12'TL and they looked really small. If your staying stock-ish height go with 20's otherwise get the 18's and lower it(a lot) Just my opinion though.
The Original Shawdy
He's looking at 19's or 20's. Yes aftermarket 18's are not worth it and too small. Whatever size you choose will look good with a drop.
5th Gear
I had those wheels left-over from my Si, just wanted to see how they looked. If your going to put money into a good set of wheels set aside some extra for a good set of coilovers as well. The end result is well worth it!
they wont fit because si has 5x114.3 bolt pattern, and our car has 5x120
My 20x9 +35 fit fine. I'm lowered on Tien S/A's with a one finger gap. My wheel is 12.6mm wider, 6.3 on outside, 6.3 on inside and My +35 offset has 3mm less poke, so a 19x8.5 +32 will have 3.3mm less poke than mine and I feel should got fine.
