TEIN SS with EDFC self install - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Fourth Generation TL (2009-2014) > Tires, Wheels & Suspension
Log In
LinkBack Thread Tools Search this Thread
Old 03-21-2011, 08:51 AM   #1
Registered Member
jnc2000's Avatar
Trader Rating: (0)
I don't have a FB I don't Tweet Fart Box Play with me
Was a major PITA, but well worth it in the end. A big thank you to forum member and friend gerzand.
Bottom line, each the fronts took less time then one of the rear. Overall the suspension on the 4G is more then a PITA to work on then the 3G - and at the recommended drop levels that TEIN gives you the OEM 18's do tuck.
The EDFC is not too bad. Depending on where you install the controller is another story. I chose the glove box which meant dropping the HVAC blower unit to access the grommet on the passenger side firewall.
More picture forth coming - but for now, cell phone pics.
Click the image to open in full size.
jnc2000 is offline   Reply With Quote
Old 03-21-2011, 09:59 AM   #2
I have car ADD
BLACKURA_NY's Avatar
Trader Rating: (6)
OMG! Sex on wheels
I am so sad that I can't put my coils on my TLs anymore... i use my car for work more than ever now (25-30k a year) and I regularly have important corporate partners in the car, so driving a slammed, bouncy car isn't ideal...
i like my H&R springs, but DAMMMNN your car is looking BOSS
__________________
Current 2014 Infiniti Q50S AWD Deluxe Touring 2003 Acura CL Type S
Past 2012 Audi A6 3.0T Prestige | 2010 Acura TL SH-AWD | 2009 Acura TL SH-AWD | 2008 Acura TL Type S | 2006 Acura TL
BLACKURA_NY is offline   Reply With Quote
Old 03-21-2011, 10:07 AM   #3
Registered Member
jnc2000's Avatar
Trader Rating: (0)
Thank you!
Oh I drive.... believe me 30-45k a year
just crossed 12k this weekend. Even with this ride height it is not bouncy or harsh, actually on the TEIN recommended setting (6) it's softer then stock at this height. I have 3 presets for my driving programed into the EDFC - 6, 8, and 10 - even at 10 the ride isn't bad. I wouldn't feel ashamed taking a vendor or partner out in this car at all (as I oven do!)
I'm very very impressed with the TEIN setup - esp with the addition of the EDFC controller.
With my custom 19x9 RonJons coming and the RonJon grill I'll be set for summer
Old 03-21-2011, 11:35 AM   #4
I have car ADD
Trader Rating: (6)
maybe i should ditch the H&R's and go with tein SS again... decisions decisions decisions
still drooling at your pics!!
__________________
Old 03-21-2011, 05:40 PM   #5
Chapter Leader (Northeast Florida)
FYAH TL's Avatar
Trader Rating: (0)
Nice mod OP. I have 20's and with the TEIN SS the ride is just smooth...Looking at the pics you might need a camber kit based on how low you go.
__________________
2010 TL SH-AWD 6 spd M CBP
ALL PARTS SOLD.
FYAH TL is offline   Reply With Quote
Old 03-21-2011, 05:52 PM   #6
Registered Member
djtanveer's Avatar
Trader Rating: (0)
DJTanveerSF DJTanveerSF DJTanveer
that looks amazing!!!!!
so how would you rate the installation difficulty on a scale of 1-10? 1 being the easiest. I plan on eventually getting coils and would like to install them myself.
__________________
Royal Blue 09 TL 3.5l First 4G TL On Air? Accuair management + Airrex air struts 20" BC Forged HB29/ATLP J-Pipe and Cat-Back Non resonated/JL W6 10"/OEM under spoiler kit/ 35%,15% 3M ceramic tint/ Type 2 v-leds switchbacks, full LED interior/ LED DRLs/ Tein SS coilovers/ hid fogs/Ronjon "A" bar grille, Rear roof spoiler My progress thread <>
djtanveer is offline   Reply With Quote
Old 03-21-2011, 05:54 PM   #7
Former Sponsor
rondog's Avatar
Trader Rating: (1)
ronjonsportdesign Rondy Marji
Justin, call me, I have updated 3D images of your wheels. I say 5 spokes instead of 7, saves weight.
rondog is offline   Reply With Quote
Old 03-21-2011, 07:27 PM   #8
Registered Member
gerzand's Avatar
Trader Rating: (3)
gerzand
Thanks for the recognition Justin. I now consider myself a "master" EDFC installer LOL. It was fun...and time consuming. But nothing is better than seeing the fruits of ones labor!
__________________
My youtube channel:
http://www.youtube.com/gerzand
*Current: 2007 NBP Acura TL-S 6MT w/ C38-92 Rotrex Supercharger & J32A2 Headswap 634whp/490wtq at 15psi
**Daily: 2014 Hyundai Veloster 6MT Turbo
gerzand is offline   Reply With Quote
Old 03-21-2011, 07:43 PM   #9
Registered Member
jnc2000's Avatar
Trader Rating: (0)
Those pictures are pre-alignment. We had to undo a bit of the rear suspension to get the rear struts out.
As for difficulty - make sure you have a friend, and knowing the TL's suspension is very helpful. Both andy (grezand) and I have worked on the 3rd gen's suspension before installing our own, and others coilovers.
For the 4th Gen TEIN SS you will re-use the OEM top hats. it does require un-doing of a bit of the rear suspension to remove the strut. You can do it without removing the end-links but it's a PITA. Front's are way easy. You're normal 14mm and 12mm bolts up top, and the bolts holding in the forks and it drops away.
If I had to rate the difficulty with EDFC I would put it at a 9. If you choose to use the OEM grommet on the firewall to pull the front EDFC wires through you'll find it's not accessible by removing the glove box. You must drop the blower motor in order to access the grommet and pull the wires through. Then tap into a 12v switched, 12v constant (fuse panel with open slot in kick panel) ground, and dimmer in for the EDFC unit.
Old 03-21-2011, 08:37 PM   #10
I have car ADD
Trader Rating: (6)
^ when i installed the EDFC on my 3G, i actually clipped the wires in half... and ran it through the firewall that way... it was easier than trying to run it through with the large plastic plugs on it
__________________
Old 03-21-2011, 08:47 PM   #11
Registered Member
jnc2000's Avatar
Trader Rating: (0)
The plugs weren't that bad... it's more the location on the 4G that sucks.
Allan, check out my other thread for updated pictures:
http://tl.acurazine.com/forums/showt...1#post12801919
I vote you get the TEIN's on you're new 4G
Old 03-21-2011, 10:00 PM   #12
-Brian
Nexson's Avatar
Trader Rating: (0)
that looks fantastic, i wanted to just get springs, i am stick of crappy rides on my accord when lowered on all sorts of suspensions. Even had tein ss.
You can assure the ride is good?, Worth it to get the EDFC?
Nexson is online now   Reply With Quote
Old 03-21-2011, 10:19 PM   #13
RIP RBP
upnout's Avatar
Trader Rating: (6)
It looks good dropped
good mod
__________________
07 KBP
RIP 06 3G: Work VS XX/ Blackedout V2 headlights Thanx JnC/ 05 Accord fogs/ Modified 07-08 base type tail lights Thanx AckTL05/ Tinted type S side markers/ Independent DRL using factory switch/ Tein Street Flex
upnout is offline   Reply With Quote
Old 03-22-2011, 12:42 AM   #14
Administrator
Regional Coordinator
(Mid-West)
Steven Bell's Avatar
Trader Rating: (2)
steven.bell www.linkedin.com/pub/steven-bell/7/47b/a10
jnc, the coils make all the difference in the world. I know you have a huge sense of accomplishment because you did it yourself. Congrats man.....
2011 National AcuraZine Meet-Kansas City-June 12, 2011-Details Here!
__________________
20% Tint--Tinted License Plate Cover--ASM Color Keyed Engine Covers--Momo Shifter Knob--Roof Spoiler--Dead Pedal w/Type S Logo--Carbon Fiber: Interior Trim Kit, OEM Steering Wheel, Emergency Brake & ACURA Nose Logo--Shaved Door Handles--Chrome Inlay Door Handle--Audi Style LED Headlights w/Carbon Fiber inserts & switchback bulbs--ACURA logo'd: Valve Stem Caps, Side Mirrors & License Plate Screw Covers--Red LED interior underdash lights--Nokya 7000k fog lights & DRLs--Red doorlight bulbs--Red ACURA illuminated door sills--Amp'd Emblem lighted nose & trunk "A" logos--H&R Sports Springs--Progress Rear Sway Bar--Eibach Adjustable Rear Camber Kit--5k LED License Plate bulbs--Red Lug Nuts--P2R Chromed Throttle Body Spacer--RV6 V3 Long Tube J-Pipe--Continental ExtremeContact DWS Tires--5K LED Interior Cabin Light Bulbs--AckTL cleared taillights with Carbon Fiber inserts--Red Brembo Brakes and Premium Gold Pads, Red Rear Brake Calipers--Akata Spacers: 15mm (Front) & 20mm (Rear)--Aspec Kit--USR Switchback Side Markers--Rear Brembo Brake Covers--AEM Short Ram Cold Air Intake--Sickspeed Oil Cap--KP Technologies Window Roll-Up Module
Steven Bell is offline   Reply With Quote
Old 03-22-2011, 05:47 AM   #15
Registered Member
jnc2000's Avatar
Trader Rating: (0)
Nexson -- Ride is real good even with drop. Without EDFC and adjusted to TEIN's recommend setting (full hard) then back off 10 -- so that makes it 6 and 6 front and rear it runs slightly softer then stock. With the OEM 18's I feel less imperfections in the road, and it still remains taught when needed.
upnout -- Agree I can't stop looking at it. My friend and I are going to have to compare clearances and ride heights from 4G to 3G because he has a similar drop
Steven -- The coils do make a difference - knowing I did the work again, while in the end may have busted a few knuckles was well worth it. I have a whole new admiration for my car!
Old 03-23-2011, 03:36 PM   #16
Registered Member
jnc2000's Avatar
Trader Rating: (0)
I was right.. right now I'm running a -3.1 in the rear and a -1.3 in the front.
Time to order the camber kit
Even with all that suspension work toe wasn't that much out of alignment. I'm glad I bought the unlimited alignment package though because I'll sure be using it
The Following User Says Thank You to jnc2000 For This Useful Post:
midnite_tl (08-05-2011)
Old 08-05-2011, 04:23 PM   #17
Registered Member
Trader Rating: (0)
Had Teins installed in July when I was home I leave, didn't have the time to do it myself, but I couldn't be happier, EDFC to follow in the fall.
Thanks jnc for selling me on the Tein SS this past spring.
Running -2.75 in the rear and front is good with a 1.25" drop, suggestions for correcting this camber issue?? Alignment shop claims I have no room for a camber correction kit, wheels are too wide.
midnite_tl is offline   Reply With Quote
Old 08-08-2011, 02:42 PM   #18
Registered Member
KB1Spec's Avatar
Trader Rating: (4)
You install your EDFC at the glove box? I installed my on the coin tray between the shifter and radio unit.
KB1Spec is offline   Reply With Quote
Old 08-08-2011, 02:45 PM   #19
Registered Member
jnc2000's Avatar
Trader Rating: (0)
if the rim / wheel combo your running will not allow correction after camber kit installation it's time to roll your fenders.
drop + wide wheels/aggressive offset(s) often necessitate rolling of fenders. to achieve that perfect stance.
__________________
Quote:
Originally Posted by SSFTSX
Imagine Accord Coupe V6 6MT with DI engine and LSD with Pilot Super Sport. It will be in class of M3.
midnite_tl (08-09-2011)
Old 08-08-2011, 02:48 PM   #20
Registered Member
jnc2000's Avatar
Trader Rating: (0)
Quote:
Yupp
__________________
Acc-Rite (12-30-2012)
Old 08-08-2011, 03:17 PM   #21
Registered Member
KB1Spec's Avatar
Trader Rating: (4)
I thought about in the glove but kind of far reach if I want to adjust the suspension on the fly. So I put it inside the coin tray. Will post pic later...
Old 08-08-2011, 03:20 PM   #22
Registered Member
jnc2000's Avatar
Trader Rating: (0)
I don't usually adjust the suspension on the fly... 12F / 11R seems about the perfect combo for my driving / road conditions.
Plus, I store a small bottle of cologne in the "Not An Ashtray" for the ladies :P
__________________
Old 08-08-2011, 03:45 PM   #23
Registered Member
KB1Spec's Avatar
Trader Rating: (4)
lol good call
Old 08-08-2011, 04:41 PM   #24
Registered Member
KB1Spec's Avatar
Trader Rating: (4)
My EDFC
Old 08-09-2011, 04:51 PM   #25
Registered Member
Trader Rating: (0)
I just might do that, well I can't do anything over here, but I will be back in a couple weeks and then I will get back at it. My only other option is rotate the tires more often to keep the wear down I guess.
Old 05-22-2012, 11:55 AM   #26
2012 TL SH-AWD
Zelaya's Avatar
Trader Rating: (1)
Hey KB1Spec, can you close the " This is not a ashtray" with the EDFC? I'm still thinking either install it on the glove compartment or your setup.
Zelaya is offline   Reply With Quote
Old 05-23-2012, 12:51 PM   #27
Registered Member
Blueberryyumyum's Avatar
Trader Rating: (0)
Not to bring this thread back from the dead but which chamber kit did you choose to go with?? I would PM you but think many lurkers on this forum will probably want to know as well =)
Blueberryyumyum is offline   Reply With Quote
Old 05-23-2012, 01:36 PM   #28
Almost Baņņed
potmilkz's Avatar
Trader Rating: (0)
Quote:
off topic. lol
but to answer your question, go with spc.
potmilkz is offline   Reply With Quote
Old 05-23-2012, 03:36 PM   #29
Registered Member
Trader Rating: (0)
Quote:
Originally Posted by potmilkz View Post
off topic. lol
How is asking which camber kit he choose off topic?? Is the question suspension related to JNC's setup? Yes... Has JNC clearly stated the amount of drop he's on with the neg camber he was currently at on post #16? Yes... Thanks for answering the "off topic question" which wasn't directed towards you
Old 05-23-2012, 05:28 PM   #30
Almost Baņņed
potmilkz's Avatar
Trader Rating: (0)
clearly you haven't done your research..
there is only two possible camber kit on the market.
spc or j-power.
spc = more expensive, quality is top notch
j-power = less expensive, unknown quality but vouched by many members
now really think to yourself.. which one JNC used on his 40k car..
its not rocket science
Old 05-23-2012, 08:55 PM   #31
Registered Member
Trader Rating: (0)
Ingalls and Eibach also make camber kits as well for the 4G.. Clearly you haven't done your research... All are reputable brands with comparable prices..
Researching> E-Thuggin
Old 05-24-2012, 12:32 AM   #32
Registered Member
jnc2000's Avatar
Trader Rating: (0)
SPC guys... its not really a question
__________________
Old 06-07-2012, 03:40 PM   #33
Registered Member
VRCD_NY's Avatar
Trader Rating: (0)
dannyrivas296
Just a stupid question, im getting my tein ss today, will it void my warranty? Jnc your whip looks sick!! Thanks guys!!!
VRCD_NY is offline   Reply With Quote
Old 06-07-2012, 09:23 PM   #34
Registered Member
jnc2000's Avatar
Trader Rating: (0)
No the manufacture can not blatantly void the warranty on the car due to the installation of an aftermarket part. However, if the aforementioned aftermarket component causes a failure / or compromises the integrity of an OEM part which would question the legality of a warranty clause they would be within their rights to void the warranty on that part of the car.
IE: Coil overs -- and you have suspension problems afterwords.
-- they couldn't not cover something not directly related (ex: EGR/ drive train -- unless the it is a drive-shaft and they intent to prove adverse wear due to stress of the aftermarket component....) -- you see its really a grey area in you need to really read up on your rights as a consumer. Hold the dealer to the wall if you have an issue, and don't be afraid to press it if you feel you are within your rights. Now if you cause a failure and try to get it covered... man up and pay for it.
__________________
Old 07-22-2012, 07:49 PM   #35
Registered Member
Trader Rating: (0)
question from a noob here, if I go with the TEIN SS and don't drop the height too much do I still need the camber kit?
sympley is offline   Reply With Quote
Old 07-22-2012, 08:48 PM   #36
Registered Member
dragonwang's Avatar
Trader Rating: (0)
Most likely not. My H&R dropped the fronts and rear by an average of 1.3" F/1.4" F respectively and I did't need a camber kit.
__________________
2010 Acura TL SH-AWD WDP 6MT - Nice and Clean Modified
2008 Infiniti FX35 AWD - Weekend Hauler
2001 Toyota Corolla LE - Canine Mobile
dragonwang is offline   Reply With Quote
The Following User Says Thank You to dragonwang For This Useful Post:
sympley (07-22-2012)
Old 07-23-2012, 12:03 PM   #37
Platinum Sponsor
Excelerate's Avatar
Trader Rating: (1)
ExceleratePerformance
Quote:
You would have to get an alignment or at least determine how much your camber/toe is off in order to know that for sure.
__________________
Excelerate Performance
Connecticut's Finest Full Service Shop and Master Distributor For:
STOPTECH | TEIN | HONDATA | XLR8 | ISC | Kraftwerks
Instagam @excelerateperformance | Twitter @ExcelerateCT
Facebook Page! |Web Store!
Excelerate is offline   Reply With Quote
Old 07-27-2012, 07:02 PM   #38
Registered Member
Trader Rating: (0)
KB1SPEC, how did you run your wiring for the EDFC in the tray? Did you had to take the dash apart? It looks really good in that spot.
Old 12-12-2012, 02:45 AM   #39
Registered Member
Trader Rating: (0)
Bump on this question, I'm interested in that area in general and would appreciate any info on how that part of the dash comes apart.
ReneC is offline   Reply With Quote
Old 12-12-2012, 06:54 PM   #40
Almost Baņņed
potmilkz's Avatar
Trader Rating: (0)
oh sorry i miss this.. but were you looking for just a front ball joint and a rear toe arm? because that is what Ingall offers.
what about your rear lateral arm and rear camber arm? I was under the impression that you were looking for a full 3 piece rear kit with a front ball joint kit..
You are right that they are all reputable brands but Eibach and SPC are the same product, eibach just sells it with their name on it. if you go to eibach and spc website and look at their part number, you will know..
CLEARLY you havent done your research..
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS: 05 WDP Acura TL FULL PARTOUT (ALL MUST GO) - Comptech, RV6P, Tein, Defi, Pioneer, AEM BoricuaTL Car Parts for Sale 111 01-22-2016 02:00 PM
CLOSED: 4G TL Going Back to Stock (coils, intake, mats, etc...) nanos Car Parts for Sale 26 11-12-2015 09:41 PM
FS: Custom headlights from AckTL TLrascal Car Parts for Sale 7 11-01-2015 01:45 AM
Advance running boards installation giovane DIY & FAQ 11 10-07-2015 06:10 PM
Clutch Pressure Plate Alignment TxRzrBk Problems & Fixes 0 09-17-2015 02:07 PM
Tags
2010, 3rd, 4g, acura, coilovers, edfc, gen, install, installation, pics, ss, suspension, tein, tien, tl, tls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
