20x10.5 45 offset square setup?
5th Gear
Hi guys, i just found some sweet set of vossens for $1500 and the size is 20x10.5 45 offset. If this was asked before i apologize but am in a hurry as this deal wouldn't last. Thank you.
what model is it? is your car lowered though? if not this set up will easily work. if you are lowered than you could still run that size but you may need to make some adjustments. should work fine though. good luck and let us know how it goes
Are you willing to roll your fenders and possibly make some camber adjustments because you might have to make some adjustments to get these wheels to fit depending on how much you lower your car. You should be fine though
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
