20x10.5 45 offset square setup?
Old 04-01-2015, 10:26 PM
5th Gear
The Black Label's Avatar
Hi guys, i just found some sweet set of vossens for $1500 and the size is 20x10.5 45 offset. If this was asked before i apologize but am in a hurry as this deal wouldn't last. Thank you.
Old 04-01-2015, 11:13 PM
ffmjst's Avatar
what model is it? is your car lowered though? if not this set up will easily work. if you are lowered than you could still run that size but you may need to make some adjustments. should work fine though. good luck and let us know how it goes
Old 04-02-2015, 01:03 AM
5th Gear
Thanks for your reply, my car is a 2012 tl base fwd and its not lowered at the moment but will purchase tein sa coilover soon
Old 04-02-2015, 09:07 AM
ffmjst's Avatar
Are you willing to roll your fenders and possibly make some camber adjustments because you might have to make some adjustments to get these wheels to fit depending on how much you lower your car. You should be fine though
neuronbob
23
07-16-2019 10:48 AM
gatrhumpy
19
12-31-2015 04:22 PM
SinCityTLX
55
10-11-2015 01:20 AM
Ratheruneeq
09-28-2015 07:41 AM
dirleton
09-25-2015 12:25 AM
Quick Reply: 20x10.5 45 offset square setup?
