SPC rear camber adjustment
I got my car aligned after I installed the camber kit, but the dealer did not know I had a kit installed. Luckily my front kits are within spec on the first try, but I found my rear to be 0.9 degrees positive. Does anyone know how many turns I have to make on the SPC kit to get 1 degree of negative adjustment?
Not Asian
Didn't know??? I guess they didn't even look at the rears? It's quite obvious. You can't really judge the camber on a number of turns. You can only I ball it. How did you get a postive camber anyway? If they were installed correctly, you should have a negative camber.
Not Asian
Originally Posted by genghis82
I added about 4 turns to the stock length of the SPC kit. I heard about 3 turns gets you a degree, but I wanted to confirm this.
Not Asian
I would take it back, but the acura dealer says that adjusting camber is an extra $30 fee. I've adjusted the rear camber by 2 threads for now.
Did you just get a front-end allignment? Or a four-wheel allignment
rockyboy
12-06-2022 02:29 PM
09-14-2015 10:48 AM
