-- FAQ: wheel rim size "will they fit?" --
Old 09-05-2007, 04:09 PM
  #281
B A N N E D
VeEzy's Avatar
^if you look at the first page on this thread it says 8.5 is too wide unless you do custom body work
Old 09-08-2007, 06:12 PM
  #282
pgarratt's Avatar
Sorry if this has been asked before, but i can't find anyone asking....will 3G wheels fit onto a stock suspended 2G? 2007 type-s wheels are 17x8, but they're 45 offset (i read the first page and he recommends 48).
-Pete
Old 09-11-2007, 01:03 AM
  #283
JALEMANGDA's Avatar
AsianRage,
19x7.5 w/ +42mm offset on my 02 TL-S rubbed only when i have 3 people in the back or 2 people w/ some luggage. i do not reccommend 225-35-19 cuz dem potholes and railroad tracks can be unforgiving.
Old 09-30-2007, 09:30 PM
  #284
Bippu Style only please
02AcTLS's Avatar
I think this list needs some updating.
Specifically a section for people who have done the modifications to get wider, lower offset wheels to fit, and their sizes. It's really not all that extreme from what I have viewed getting under the car, so it's not like you're reforming the fenders or anything; sure rolling the fender, but that's not what I mean by reforming...
Anyways,
I've searched and searched, and only found a few threads about wide, low offset wheels, and not much information was thrown in. It's put me into a position to contact people at JDMPalace and Memoryfab.
Old 10-02-2007, 07:44 AM
  #285
Keep it flush!
djescobar973's Avatar
18.x7.5 5x114 35.73
225/40/18
Will these do the job...
Old 10-13-2007, 02:07 PM
  #286
hAadOokEn's Avatar
help thx
i've read through 5 pages and i'm tired and can't find my answer except not to do it if the offset is low.. i would like to know for sure if
Axis Reverb
18x8.5 35 offset would fit on my 2nd Gen TL
i cut the tabs and rolled my fenders would it fit??
and im lowered on h&r sports
Old 10-14-2007, 12:24 AM
  #287
02AcTLS's Avatar
My personal opinion? After looking into the wheel wells myself, I think those would fit. From what people say, an offset that low means you'd have to roll some camber (in my opinion that's NEVER a bad thing) so it depends on how much you wanna spend on tires, and how often.
That's just me. I'm all about that particular style, which is what 99% of this community is not about.
Old 10-14-2007, 10:06 AM
  #288
derrick's Avatar
Axis Reverb
Let's do some math:
8.5" rim is 2" wider than OEM rim ... (2" = 50mm)
offset +35 is 20mm LESS than OEM rim
So ... 50 + 20 = 70mm (2.75" further out than OEM ... if you still have OEM rims on ... there is no way this will fit without you 'tucking' the rims in (ie negative camber). You're also lowered ... so my answer will be:
You want deep dish on a car ... either go custom rims, widebody modification or ... buy a different car. Sorry, our cars for the most part are horrible when it comes to rim options.
Old 10-17-2007, 09:33 AM
  #289
JCharged's Avatar
18 x 8 +40 offset and what tire size will fit on my TL?
Old 10-19-2007, 05:17 PM
  #290
derrick's Avatar
^ That wide a tire and low an offset? Go as thin as possible.
I would say 225/40/18 is a safe size ... but go with a different rim if you can.
Old 11-14-2007, 02:15 PM
  #291
EL19's Avatar
dam Derrick I was just about to get a bomb ass deal on some 18x8.5 aspec wheels...so they wont fit eh?
Old 11-20-2007, 07:32 PM
  #292
derrick's Avatar
^ Not unless you plan on going stock height ... then you'll be looking like a 4x4. Those who have it will definitely have to cut tabs + roll fenders ... and you'll still have rubbing issues.
Old 11-23-2007, 12:59 PM
  #293
EL19's Avatar
another question...i foudn 2 sets of rims...one set is 18x7.5 with a 40 offset and the other set (Enkei) is 18.7.5 with a 42 offset...will they fit? if so which the best and would i have to go with a low pro tire i.e 225/40/18? thanx
Old 11-28-2007, 10:21 AM
  #294
VIP typ-S's Avatar
2nd gen TL-S looking to put 18x7.5 +55 offset all the way around.
or 18x8.0 +50mm all the way around.
Will they rub ? or stick out ?
Old 12-01-2007, 10:29 AM
  #295
derrick's Avatar
Following this general rule:
Our TL/TLS come with 6.5" rims with +55 offset, made my Enkei. General rule (but not always the case since there is some variation among manufacturers):
7" rim = +42 offset
7.5" rim = +45 offset
8" rim = +48 offset
> 8.5" rim ... forget it unless you wanna do some custom bodywork for it to fit.
I would probably pick the Enkei with the +42 offset. Not much a difference, really ... but every mm does add up! And I would go with a thinner tire (225/40/18) such that it reduces chances of rubbing, compared to a 235/40/18 tire. (And 225 tires are a lot cheaper in comparison to 235 tires!!!)
Old 12-01-2007, 10:40 AM
  #296
derrick's Avatar
18x7.5 +55 ... no problem
18x8.0 +50 ... should be no problem either. If anything, the tab might need to be cut, but that's very easy to do if you have Dremel (or access to one). Pick a thinner tire (225/40/18) and that should reduce the need to cut tabs.
Old 12-02-2007, 09:30 PM
  #297
MurdaZ's Avatar
would 18x8 +45 offset work with 225/35-40/18...being lowered?
Old 12-02-2007, 09:46 PM
  #298
TwinTurbo335's Avatar
Ok, I already got my rims already. axis hiros 19x8.5 45 offset with toyos t1s 235s.
what would I need to do because I just lowered my car today and about to put on rims tomorrow. I am lowered 2.2 inches front 1.8 rear. Will i need to cut tabs and roll fenders?
Should I get a alignment right after I put on the rims?
Old 12-02-2007, 09:48 PM
  #299
MurdaZ's Avatar
your going to rub man, 235 with a 8.5 rim...
Old 12-02-2007, 11:09 PM
  #300
'03TL-S's Avatar
Yes you will rub also along with the 235s and being lowered. With some fender modifications, it'll fit.
Old 12-02-2007, 11:24 PM
  #301
i guess i will just cut the tabs. how much does it cost to tell a shop to cut tabs?
Old 12-03-2007, 06:03 PM
  #302
Pearl TL-S's Avatar
Somebody help me out here, I'm a little slow...............19x8 +55mm offset......Will that work on an "03 Type S?
Old 12-04-2007, 10:16 AM
  #303
'03TL-S's Avatar
That will definitely work.
Old 12-04-2007, 11:09 AM
  #304
ok. so i just installed my rims. 19x8.5 45 offset. and when i am by myself it doesnt rub. but when i have 2 people in my car.. feels like the front and the rear is rubbing alil bit. So what would u guys prefer me to do? cut tabs and roll fenders? and also, whenever I drive and let go of my acceleration. The pedals starts to shake. Is that normal?
Old 12-05-2007, 10:22 PM
  #305
pnthr30's Avatar
I believe this will work, but can someone please confirm......
Car: 03 TL-S
Rim: 18 x 7.5
Tire: 225x40x18
Car is not currently dropped......thinking about putting on a slight/modest drop, would I still be ok?
Thanks a lot.
Out of curiosity, what do you guys think of these? Car is black, tinted windows, black headlight housings, and smoked out fogs (tinted during the day and yellow light at night).
Old 12-06-2007, 10:15 AM
  #306
here comes the snow!
sfont012's Avatar
i have 225/40/18 on my car and they look small ! big gap in the wheelwell
Old 12-07-2007, 09:28 AM
  #307
5th Gear
skhangwp's Avatar
Will these fit okay?
19x8.5 with a 5x4.5 (5x114.3) bolt pattern and +50 offset.
Will this fit okay? Anybody? Help me please!!! These are some bad a** chrome rims that I want on my 03 TL-S...
Thanks!
Old 12-07-2007, 09:45 AM
  #308
5th Gear
skhangwp's Avatar
Talking Derrick, the Pro...
Derrick, you seem to be the pro, would this work?
Will this fit okay? These are some bad a** chrome rims that I want on my 03 TL-S...
Thanks!
Old 12-07-2007, 10:29 PM
  #309
Never Summer's Avatar
Hey guys any chance I would be able to fit 235/35R19 tires on the TL? If not, what size tires would work best for 19x8.5 rims? Let me know. Thanks. (I do realize the thread says 8.5 wont fit, but I believe quite a few people have made it work.)
Old 12-07-2007, 11:13 PM
  #310
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Tire width has alot to do with rim offset. What offset
Old 12-07-2007, 11:15 PM
  #311
fsttyms1's Avatar
Thanks!
It will be close. You will probably have to trim the tabs and roll the fenders.
Old 12-07-2007, 11:16 PM
  #312
Scru U guyz, Im Goin Home
boku's Avatar
Originally Posted by fsttyms1
Tire width has alot to do it (misquote)
That goes for skhangwp's question too (even tho I'm not derrick)
Old 12-08-2007, 09:57 AM
  #313
I believe the offset of the rims is 38...
Old 12-08-2007, 03:42 PM
  #314
T-Swzy
Razzi's Avatar
how'd u manage to make a 38 offset 8.5 wheel to fit?
Old 12-08-2007, 03:48 PM
  #315
-Arsenic-
02type-s's Avatar
You would have to stretch a 215/35 or a 225/35 with rolled fenders, cut tabs and negative camber to get that one to work.
Old 12-08-2007, 03:49 PM
  #316
-Arsenic-
02type-s's Avatar
You would have to stretch a 215/35 or a 225/35 with rolled fenders, cut tabs and prolly a little negative camber to get that one to work.
Old 12-10-2007, 06:07 PM
  #317
derrick's Avatar
Take boku's word for it ... this guy pushes the limits on wheel offsets for a 2nd gen TL (along with other members ... but boku uploads pictures enough for me to remember ... LOL ...)
To the guy with the 19x8.5 with +38 offset ... you should definitely reconsider that setup for a 2nd gen TL ... that is way too wide a rim and way too low an offset. I know you want VIP style ... but stretching tires and tucking the rims in (ie negative camber) ... doesn't make sense to have to change tires every 10,000 miles since your rims don't work. Maybe for a show here and there but definitely not for daily driving.
Old 12-13-2007, 07:20 PM
  #318
Unregistered user
LIPPSTUH's Avatar
03 cl dropped on apexi coilovers
i know that 8.5 with a 50 offset is pretty much it for our cars.
but i know rev did a 9.5 before....
would 19x9.5 +55 offset fit and with what modifications if possible. 225 tires of course
Old 12-13-2007, 11:46 PM
  #319
-Arsenic-
02type-s's Avatar
Wasn't he hella cambered tho? You could run that if you wanna buy tires every 10,000 miles like Derrick said.
Old 12-18-2007, 12:25 PM
  #320
derrick's Avatar
Quick one ...
8.5" with +50 offset ... you will barely make it if you cut tabs / roll fenders.
9.5" with +55 offset (math: 1" = 25mm ... offset measured in millimeters)
So essentially you are going 20 wider (-25 mm rim + 5 mm offset) ... no way unless you plan on driving with negative camber (or a custom widebody kit)
Quick Reply: -- FAQ: wheel rim size "will they fit?" --
