Would alcohol damage my paint or the clear coat?
Yes. My grandfather uses denatured alcohol to get tree sap off his cars(Saab and Volvo) and they are that "old people" color(sand) and the stains still shows up, despite my waxing the cars multiple times.
Mike
Mike
Team Nighthawk Mambo King
clay bar and if that doesn't work, a little gasoline ( don't bash) in a rag will do the trick, but afterwards wash it with dishwashing liquid (Dawn) and wax it with a few layers of good wax ...top it off with a layer of Meguiers's NXT.......
Originally Posted by rodneyc77
alcohol would remove all the oils, grease and waxes off the paint... I never heard of alcohol messing up a car's paint... just make sure to wax the area after using the alcohol (rubbing)
also, honda/acura dealers have a product i use frequently that work very very well called "Spray Cleaner & Polish". i love this stuff. comes in a spray can, spray on rag or micro fiber towel liberally then use on needed area. this is the product we use for the notorious 3g TL dash fading or turning white problem. works awesome.
'04 6mt Pearl
What type of glue is it ? Some glues can't be dissolved easily. If WD40, Goo Gone, Gas, or diesel doesn't work, you could try buffing it out with a micro-fiber cloth and a mild abrasive pre-wax cleaner like Mothers.
Ive used goof off to get gunk off all my cars, I even did it to a whole hood before, worked great and didnt damage the paint, anything you try you always want to test it somewhere first tho
you can also get a can of Paint Cleaner or Clear Cleaner from an Auto paint store...a lot of detailers use it to get abormalities off of old wax and clear coat....you have to use it in small doses and it DOES take off all the wax in the area you clean right down to the clear...just make sure you wear gloves and wax the car when your'e done...
Unregistered User
There isn't much that will hurt the clear coat. Gas, alcohol, goof off, etc. won't bother it one bit. But when you're done, do wash well and put several coats of paint.
IF something was on the car and there's marks after, it's most likely from sap, bird crap, etc., NOT what you used to clean it.
IBankMouse
06-13-2020 12:53 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
