wire for the dome lights
06 6spd TL BAGGED
Does anyone know where to find the power wire from the dome light switch?
i'll be tapping the puddle lights i got to this so when i open and close the door, the puddle lights will come on along with the interior lights. thanks
Retired!!! ON TOP!!!
I got y'all covered... the dome wire circuit is very trickie... But I'm willing to help you guys out...
What do you want to achieve??? Do you want to hit the remote and when the doors unlock you want the lights to turn ON??? Do you want to turn on the accessories with the dome lights too???
Let me know... then I'll give you the right wire and what to use to wire it up correctly... 'cause I've already did it for my door handles LEDs...
Brooks Hoy (04-10-2015)
I did the puddle light mod awhile back. I used the dome light wires that are located in the a-pillar. If I remember correctly one is gray with a blue stripe and the other is green with red, I think the gray is the + and the green is the -. I remember these 2 wires being thicker then the other wires in the a-pillar.
I have puddle lights wired to the dome lights so they come on/off when you lock/unlock the doors.
06 6spd TL BAGGED
06 6spd TL BAGGED
Just did my testing. The rear map lights have three wires: Y - GY/BL - W. Yellow did nothing, whether the lights were on or off. It may serve some purpose when you're actually using the map light. Gray/Blue constantly fluctuated. It never made 0 volts nor 12 volts, just back and forward between 3 and 6. The white seems the most promising but it's weird. Sitting in the car with the lights off, it reads a full 12 volts but as soon as you unlock and the lights come on, zero. Like the polarity is reversed some way. Can anyone explain this?
Chapter Leader (NY/NJ)
Like Carrie mentioned... the courtesy light circuit is controlled by the negative pulse of the GREEN w/ RED stripe wire... That's how I have my door handles wired up...
The Green w/ red stripe wire can be tapped at the fuse box. It's located at the TOP RIGHT corner (back side) of the fuse box. It's the Last six pin connector (green) on the back side of the fuse box... it's a PITA to get to...
In terms of wiring... just hook up the negative wire to the Green w/ red and the possitive to a constant 12V (B+) source... and you're done... make sure to isolate your NEW circuit with the use of diodes etc...
Good LUCK
Good LUCK
i wired mine to the rear map lights.. now my puddle lights turn on whenever the map lights are on. So if I turn on the maplights, my puddle lights turn on.. whenever i lock/unlock my car my map lights/puddle lights turn on.. if i turn off the maplights my maplights/puddle lights/ DO NOT turn on .. i can do all this with the front map light switch.. i remember there being 3 wires coming out of the rear map light.. i just wired my lights into each wire and test it.. took 2 tries to get the wire right.. forgot what color the wires were tho..
06 6spd TL BAGGED
Good LUCK
Good LUCK
and is there a way of checking the codes when your check engine light is on with out using a obd2 scanner? because i remember for my integra, i could use a paper clip, bend it into a U-shape, insert it into the plug and the check engine light would flash either short or long flashes to tell you the number code. then from there, you can look at a list of number codes that stand for certain problems with your car.
Positive lead goes to Gray/Blue
Negative lead goes to the White
Oznium lights lit up brilliantly. Can't wait to install them this weekend and check the glow at night. I'll do a DIY on the process when it's all said and done. Thanks again, bzyrice (got it on the 3rd attempt) and those who contributed advice.
Also, I believe I've figured out the "reverse polarity" thing on the white wire is not that at all. The map light and courtesy light "share" either the same power source or ground. The white wire is the constant 12v source for the maps, so when the doors are closed and locked, maps are in control. When unlocked and opened, power is "shifted" from the maps to the courtesy. Which explains more for my testing because whenever I locked the doors, the white wire did not JUMP to 12v, it gradually rose. Makes sense due to the fact that our courtesy lights gradually fade out when locked. Since my TLs a base, gonna wire up and Dremel in two blue leds for each map housing and eliminate the maps as the courtesys but still keep them as, of course, map lights. I'll DIY that one too if no beats me to it.
1st TL-S on air in
sorry but do i need to use diodes? and what size/ where do i place them? thanks
Thank you, bzyrice. All the testing with the voltometer was confusing, so I went back to the basics: good ol' process of elimination.
worse thing that can happen this way is u blow a fuse =)
06 6spd TL BAGGED
06 6spd TL BAGGED
ok so i got a little problem in finding out how to wire up my puddle lights...
heres what i wanted to do.
1) have the puddle lights light up when i unlock/open the door via the interior light green/red wire.
2) be able to use the controller the puddle lights came with. the controller lets you turn your lights off and on and allows you to change the light pattern.
with that said, imagine the controller in the middle. the positive and negative wires to power the switch and lights are located on the top of the switch. the bottom of the switch has the wires that lead to the led puddle lights. there are 2 wires, one for each side of the car and each wire has i think 4 small wires in them.
now my problem is that i would need to tap 2 different sources into just one power/negative wire. how would i do this? would i need to use a relay to have it work or some kind of switch with more than multiple prongs?
i'll post up pictures of the actually puddle lights and controller in a little. thanks in advance!
06 6spd TL BAGGED
heres the pictures...
The controller with the positive/negative wires coming from the top and the wires leading to the puddle lights on the bottom of the controller.
Inside the controller. as you can see, the two wires leading to the puddle lights have multiple smaller wires in them. i was going to tap the interior light wires to these but since theres so much wires and their so small, i'm trying to find another way.
1st TL-S on air in
either you can use a on off on toggle switch or you can wire two relays so that one controlls interior lights and one for the controller. Let me know if you need help with this i think i can figure out a solution that would work. Its just easier if i can actually wire it up and work things from there.
Hey guys chime in on helping me out as well I have ozium superflux 12v prewired white LEDs and I cannot get them to turn on I tapped into the front map lights and nothing I am stumpedreally bad I taped into the a pillar were the airbag is also with no luck. Some one chime in I need this project finished please!!!!!!
06 6spd TL BAGGED
if you test them with the battery and they do work, how are you tapping into the wires in the map lights? Are you using taps or wiring them directly? I hate using the T taps because sometimes you dont get a good connection for some reason. So usually I will just strip the wire I want to get into and then just connect the two wires together.. and if there is enough space I will solder them together.. then just cover up with electric tape..
let us know what happens!
Did you ever install those puddle lights?
For all those who are wanting to install the puddle lights I really would suggest doing it through the rear map lights, just because you can remove the rear bottom seat portion and find 2 plugs that lead to the outside of the car making it very easy to wire your puddle lights to your car. Look at the first page of my thread (post #26 - near the bottom of the first page) and I took pics during the whole process.. I also give a little bit of a DIY ..
Click here to see how I did my puddle lights! Pics Included of my install
Oh yah here is a video of my car of how the puddle lights fade in and out with your car alarm .. SOO AWESOME..
http://www.youtube.com/watch?v=EjsyLOIQJIQ
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
