Warm-up time?
Old 02-05-2013, 05:59 PM
  #41
GKinColo08TL's Avatar
Originally Posted by MandoTL
Dude,
I am dead serious, as this is a forum and no need for me to start a new thread. So I see no reason to ask a simple question that is related to the topic of this thread. My situation may not be as cold as other members during winter, but it was something I just wanted a little feedback on what I was facing once I first turn the car on.
I dont let it sit[Drive off], I already replaced the switches and my last 1x3 was around 10k miles ago. I am well aware of the tranny issues with the 04s and 05s.
Its roughly low to mid 30s in the early mornings so far, but since I live on a hill, right when I reverse and move forward to school I am going downhill, the car hasn't fully warmed up yet. That is where I feel the jerking going downhill, is it the grade logic system or something I should look for.
I was only concerned with the jerking feel when its shifting from 1st to 2nd down the hill as it never really did that in normal warmer temperature and never noticed it last winter. I am trying my best to avoid any kind of tranny failure, but once I hit the flat lands after my decline the car shifts fine, and it still hasnt warmed up yet.
Please accept my apology, I was being a jerk. OK, I have an 03 Durango AWD with 121K miles on it...if I go immediately after starting that tranny shifts roughly...if I wait 30 seconds until the fluid has gotten throughout the tranny it is much happier. My 08 TL with 61K, if I leave soon after starting and I am going slowly...at idle or a little quicker I have that noticeable shift from 1st to 2nd...I would say to you...just let the fluid get into the tranny lubing all before taking off. At low to mid 30s I would say temp is not an issue. Just the TL trannys.
GKinColo08TL is offline
Old 02-05-2013, 06:59 PM
  #42
MandoTL's Avatar
Its all good man, I am just trying to avoid any possibility of slippage from the tranny. My car is joy to drive, but I never redline it, or go passed 3k rpm, I drive very conservatively unless I need to WOT to get onto the freeway which I usually have too since its a short onramp to the freeway.
I will try to sit and let it idle for a few minutes and see if that helps the shifts. My mom had a 2001 Durango SLT that had strange tire deflating problems, and her tranny was on its way out only after 2years of ownership bought brand new.
Same hard shifts I was kind of feeling in my car just had me worried of the tranny getting screwed up by the hills, since those were signs that my mom dealt with in her Durango. Warranty covered it, but my mom was just done with Dodge.
She traded it in and bought a new 2003 GMC Envoy XL SLT2 "fully loaded". So you can see why I am super observant of avoiding a costly repair.
MandoTL is offline
Old 02-05-2013, 07:28 PM
  #43
I hate cars's Avatar
Received 1,811 Likes on 1,282 Posts
The Tl pulls throttle on shifts except when cold. That coupled with cold thick fluid the shifts are a little on the harsh side.
The trans has full lube pretty much instantly. You have a very high volume high pressure hydraulic pump not to mention nothing is supposed to drain when it's off. There's a check valve to keep the converter from draining back into the pan when it's off so everything already has fluid when you start it.
A harsh shift doesn't hurt the trans. I've never been in a car that didn't shift harder when cold.
I hate cars is offline
Old 02-05-2013, 07:46 PM
  #44
Stay Out Of the Left Lane
NBP04TL4ME's Avatar
Received 1,236 Likes on 1,023 Posts
http://www.popularmechanics.com/cars/how-to/4213313
http://www.thedailygreen.com/living-...warming-up-car
NBP04TL4ME is offline
Old 02-05-2013, 07:52 PM
  #45
RaviNJCLs's Avatar
I start the car through the passenger side while I am putting my coffee in the cup holder. Walk around, get in, buckle up and go. Maybe 30-60 seconds. Not usually more than that.
RaviNJCLs is offline
Old 02-05-2013, 10:25 PM
  #46
simran4h's Avatar
does it matter how many miles on the car? or if its over 100k u let it sit for a while longer?
simran4h is offline
Old 02-06-2013, 07:33 AM
  #47
RaviNJCLs's Avatar
No. I think we all agree that cars will break over time but I see no reason to treat the TL like a fragile crystal after 100K miles. These cars are made to last.
IMO, 30-60 seconds of warm up and take it slow for the first couple miles is all you really need.
simran4h (02-08-2013)
Old 02-06-2013, 10:19 AM
  #48
Popular Mechanics: Clearances are no tighter today than the were in the 60s. The "pistons plugging up" is probably in reference to the parrafin in old oils that would build up in those conditions.
They missed a ton of valid points.
Green: Dead ass wrong about 30 seconds being needed to circulate oil. We're talking a second or less for full lube. Most areas are instant. The crank will float from residual oil the second it spins before the pressure gets there, cams are bathed in oil so it's there before the engine is started. If it took 30 seconds for oil to circulate we would be rebuilding every year or sooner.
I wouldn't trust anything from the California Energy Commission or Environmental Defense Fund. I think they just might, maybe had a hidden or not so hidden agenda.
They lie: The engine does not idle rich, WTF???
Shutting the engine off is better than idling? But if you go by their own statement it takes 30 seconds to get oil circulation. Your engine would be worn out the first time you drive across town and back lol.
Idling in the garage even with the door open can kill you.... Depends on the car. With the TL you would have to run it for hours to die even on a cold start. It's clean enough that it would have to burn all of the oxygen up. I true story that made me feel terrible... I tune the stereo every now and then with the laptop and if it's a loud tuning session I have the garage closed. I've run it for ovre an hour like that, no issues. I start it up in the morning and let it idle in the garage so it's warm when I drive it 5 minutes or less later. The fiancee sees me do this so she started doing it on her Murano which doesn't have the ULEV2 rating. She calls me and has a terrible headache. I asked her what she did different and when we finally got to the car idling for several minutes in the garage I told her to pull over, put it in park, and open the windows. I explained she can't do that in her car. Nonetheless, they make a broad generalization, some cars are perfectly fine to idle in the garage for a few minutes in the morning and the number of acceptable cars is increasing. Obviously those with the precat delets shouldn't do this.
"Block heaters beat remote starters" is a huge generalization leaving out the fact that 90% of the time warming up is better for everything but heater output. Block heaters are great but aren't cheap to install, you don't always have an outlet and they only warm up the coolant which is much better than nothing but they usually don't affect oil temp at all so the most important fluid is still stone cold. There are some great OEM tests with hot oil, cold water, cold water, hot oil, both hot, both cold in a very controlled environment. Power production and engine wear is measured. In drag racing everyone knows hot oil and cold coolant gets you down the track quicker.
"Idling is bad for your health" Idling takes very little fuel and with new cars they're still near stoich. My other car pulls less than 8gr of air per second at idle. The TL probaly uses less. In easy acceleration it's pulling nearly 100g. At 3psi boost it pegs the MAF at 255g and it has another 22psi to go. Idle is a very, very small amount of total pollution. Cars are a small percent of pollution compared to all other industry. So if idling is bad for your health, driving is a killer. They don't mention how incredibly clean todays cars are. I got my first smog check and hydrocarbons were at zero for my TL.
I could pick those things apart for days but I wouldn't believe anything from those sources.
GKinColo08TL (02-06-2013)
Old 02-06-2013, 12:19 PM
  #49
sleeper22's Avatar
IHC I enjoy reading your posts. Very informative.
sleeper22 is offline
Old 02-06-2013, 04:38 PM
  #50
Originally Posted by I hate cars
Popular Mechanics:
Only issue I have with what you say IHC is if the TL is not tuned correctly it could be producing a more dangerous level of CO. Idling in a closed garage is like playing with fire.
Old 02-06-2013, 05:04 PM
  #51
I agree and in no way am I recommending anyone do so. I've monitored 02, CO, even LEL and H2S in the garage. You're not going to have to worry about Nox at idle unless something is seriously screwed up. But yeah, not recommended. Even if it has a few misfires it will have a ton more pollution.
Old 02-06-2013, 07:29 PM
  #52
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
IHC Thanks for the posts, I know you have mentioned it before since I had a feeling of Deja Vu as I was reading through your post....
I usually park very close to the garage door, in the morning start the car up, open the garage door, go back in the house, put my shoes on, put my jacket on (30-60 seconds)....go to the car hit reverse....I go easy on the car till I get out of my subdivision and then
at times I kinda rev her up on a cold idle to hear a misfire/backfire from the true dual....bliss
swoosh is offline
Old 02-06-2013, 08:05 PM
  #53
JJH
JJH's Avatar
I'm not sure why there is a huge discussion about this. The manual explicitly states that it is not recommended nor necessary that you warm up your car before driving.
Am I missing something?
JJH is offline
Old 02-06-2013, 08:13 PM
  #54
swoosh's Avatar
Manual also states to follow the MID for oil changes which I dont
I think its just good habit like turning off the lights/ac/radio/other electicals before you turn the car off
swoosh is offline
JJH (02-06-2013)
Old 02-06-2013, 08:16 PM
  #55
JJH
JJH's Avatar
I don't follow the MID either, but that's because I use Redline full synthetic If I used regular conventional oil, I would definitely follow it. I didn't know that it was good practice to turn off the electricals...guess you learn something new everyday!
JJH is offline
Old 02-07-2013, 04:54 AM
  #56
supraru's Avatar
Can't stand the mid. Can't stand it even more when people post thier mpg's from it thinking its totally accurate. I've found on highway only drives that thing has been up to 4 or 5 mpg's off. I will say however with my commute to work every week and daily city driving its accurate. My average mph is around 33 mph then.
supraru is offline
Old 02-07-2013, 08:47 AM
  #57
JJH
JJH's Avatar
The MID is more accurate than any calculation you will be able to do with fuel economy...
JJH is offline
Old 02-07-2013, 08:48 AM
  #58
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
I agree.
My car for work typically idles all day when not actually being driven down the road. It is FAR easier on it to idle than to shut off and start as much as i would have to. In a typical 8hr day of work i will use less than 1/4 gallon gas (and that includes AC or Heat on driving in between )
There is nothing wrong nor will it hurt it letting the car idle to warm up should you want the car blowing warm air when you get in it in the winter.
fsttyms1 is offline
Old 02-07-2013, 08:53 AM
  #59
supraru's Avatar
Uhh what are you talking about? Basic math is easy. Miles traveled divided by gallons pumped=mpg. Dead accurate every time. More accurate then the mid. As a matter of fact you really can't get anymore accurate then that.
supraru is offline
Old 02-07-2013, 08:57 AM
  #60
JJH
JJH's Avatar
You're wrong. The cars computer is able to calculate the amount of fuel that is injected into the engine. That's as non-technical as the explanation gets. If you want a more technical and thorough answer, read through IHC's post history.
JJH is offline
Old 02-07-2013, 09:14 AM
  #61
Hand calculations are succeptable to pump cutoff point and other things. Most people find that as they run the average out over thousands of miles, the hand calculations and MID are very close. Unless something was done to throw the calculation off like different diameter tires, it's extremely accurate. Different stations and even different pumps at the same station can have drastically different cutoff points, more than a gallon sometimes.
Old 02-07-2013, 09:29 AM
  #62
AZ Community Team
Legend2TL's Avatar
Received 4,019 Likes on 2,497 Posts
I don't. I start it and pretty much go. I keep the RPMs down until the needle on the temp guage starts to climb. I have a 6 speed.
I have pretty much always done this.
+1
Originally Posted by Project 04TL
turn key and go .. just dont go WOT until its up to temp
+1
Just take it easy on the throttle until the engine is up to normal operating temp.
Alot of good comments in this thread.
Legend2TL is offline
Old 02-07-2013, 09:41 AM
  #63
supraru's Avatar
No I'm not. So what you're saying is you have no clue and you're taking into account something you don't know about. Oh that's right it's the Internet, everything you read on the Internet is true.
supraru is offline
Old 02-07-2013, 09:48 AM
  #64
supraru's Avatar
Same pump same station. I only get gas at one place and use the same pump every time because that's where I pull in. Mid said I got 30 mph, math said 26. It's science. Lol
supraru is offline
Old 02-07-2013, 09:49 AM
  #65
Received 16,260 Likes on 11,971 Posts
do you have a shitty attitude ALL the time?
justnspace is offline
GKinColo08TL (02-07-2013)
Old 02-07-2013, 09:50 AM
  #66
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
i don't know anyone who uses the SAME pump at the SAME gas station everytime they fill up.
what a luxury!
SharksBreath is offline
THEReeM718 (02-07-2013)
Old 02-07-2013, 10:00 AM
  #67
supraru's Avatar
No I don't, maybe you have the shitty attitude and when you read it you do it in a shitty voice in your head.
supraru is offline
Old 02-07-2013, 10:02 AM
  #68
JJH
JJH's Avatar
30 mph?
It's science? Do you mean math?
JJH is offline
Old 02-07-2013, 10:03 AM
  #69
supraru's Avatar
what a luxury!
I never said every time. But I like that you try and put words into my mouth. I would say in a given year maybe only 5 or 6 other fill ups are at a different gas station. It's called planning ahead.
supraru is offline
Old 02-07-2013, 10:04 AM
  #70
BANNED
  #71
LOL yeah your SHITTY voice. lololol
Old 02-07-2013, 10:05 AM
  #72
you never win. LOL i dont know why you try.
Old 02-07-2013, 10:06 AM
  #73
supraru's Avatar
30 mph?
Meh mpg. But mph is a word on the Internet so you should believe it.
supraru is offline
  #74
BANNED
Old 02-07-2013, 10:08 AM
  #75
supraru's Avatar
Really? Go ask your boy makk. Dude doesn't even know what a tl is and apparently the oy Honda made was an odyssey.
supraru is offline
Old 02-07-2013, 10:12 AM
  #76
supraru's Avatar
Great it's blow job time again.
Anyway my point is displays are always a general thing. He'll I can go into the computer on Subaru's and +- it I believe up to 8% if someone complains about the wrong number coming up on the screen. Subaru guys claim it's accurate as well. Lol
Does anyone actually have some info on how Hondas mid calculates it and even if it can be changed through their diagnostic computer?
supraru is offline
  #77
and once again supraru has turned a thread to shit...
Old 02-07-2013, 10:15 AM
  #78
Glad you see the trend!
Old 02-07-2013, 10:19 AM
  #79
supraru's Avatar
Really please explain how. It's always easy to spout off at the mouth like Justin and sharks breath but I only responded to what someone said to me.
supraru is offline
Old 02-07-2013, 10:22 AM
  #80
Dont feed the troll.
Quick Reply: Warm-up time?
