Very interesting conversation with my transmission builder on the TL
Old 04-16-2009, 11:33 PM
I hate cars's Avatar
Received 1,811 Likes on 1,282 Posts
I was talking to my builder who I used to work for. This guy has been doing this his whole life, owns his business, and sponsors many race cars.
We got into the TL for about an hour and I learned many interesting things.
For one I got to take a look at the trans disassembled. The third gear clutch pack is not undersized by any means. It has more than enough capacity for the TL and looks like it could support an extra 100hp easily. My builder agreed.
What he said causes the issues are the two pressure sensors going bad slowly. To make a long story short, they reduce line pressure and control shift timing in order to provide soft shifts. When one or both start to go, line pressure falls and third starts slipping. He recommended to replace both of these sensors at 50,000 mile intervals and says it will live a long and happy life if you do so.
Again, after looking at this trans first hand and especially it's frictions, there is nothing wrong with the holding capacity of the notorious third gear.
The following 11 users liked this post by I hate cars:
DaBubbla (09-21-2013), dannyz (02-20-2013), DuoDSG (04-04-2013), eastvantrading (12-06-2016), jbird2 (08-26-2013), JC06TL (11-09-2019), jgj925 (04-18-2013), mcklan (09-05-2013), sbr (06-16-2018), ThugLife07 (09-03-2013), Undying Dreams (07-19-2012) and 6 others liked this post. (Show less...)
Old 04-16-2009, 11:43 PM
Unregistered User
Rob RiL's Avatar
Sounds great but um, what are you talking about?
Like, can I just simply change the sensors in my backyard or is there a lot to it? Is it a DIY?
ONEOF137 (11-22-2012)
Old 04-16-2009, 11:49 PM
paliknight's Avatar
^^^ditto.
Old 04-16-2009, 11:54 PM
Being an Acha Bacha in
Elegant TYPE S's Avatar
Yeah he thinks all of us knows what he's talking about half the time meanwhile I always have a google page open when I'm reading his posts.. haha. What... give the tranny an ace inhibitor?
TriumphantLoser (10-27-2019)
Old 04-17-2009, 12:04 AM
Unregistered User
Rob RiL's Avatar
^lol.
╞╔╚Ä«╕\▓▒░╧»│╡¡¼ x 2 = formula for changing the sensors.
The following 2 users liked this post by Rob RiL:
Tenxbetter (02-04-2017), TriumphantLoser (10-27-2019)
Old 04-17-2009, 08:10 AM
Chapter Leader (San Antonio)
TheChamp531's Avatar
Great information! Just like they said, is this a possible DIY or do I need a professional mechanic to do? Or can you do it in your own garage with someone that knows there cars? So a Transmission cooler would be pointless since its the two sensors that causes our transmissions to fail? And does that mean a turbocharge is more possible since the transmission can actually handle a 100HP increase?
Old 04-17-2009, 08:27 AM
I think this is why some of the supercharged auto transmissions hold up fine while some stock ones die an early death. It's just the luck of the draw, who got the good sensors and who got the bad ones.
I haven't done it yet but I'm going to Acura after work today to order the sensors. They're external and the shop says it takes about 30 minutes to replace. I haven't personally looked at them yet.
Old 04-17-2009, 08:35 AM
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
Does this apply to the Auto, the MT or both?
Old 04-17-2009, 08:39 AM
Chapter Leader (New England)
JMillerUA6's Avatar
If you could keep us updated and possibly do a DIY that would be great.
Old 04-17-2009, 09:15 AM
SpecTro's Avatar
thse might be it,
http://www.acuraoemparts.com/delray/...All&vinsrch=no
12 and 13
Old 04-17-2009, 09:17 AM
myron's Avatar
this would save us alot of trouble and heartache. When I got my TL my tranny was grinding in the 3rd then I got the tranny fluid changed and it was fine but I am still feeling uneasy about it. If this is a good fix and it can be done by someone who owns a set of ratchets then this is awesome
Old 04-17-2009, 09:19 AM
All About Trance
mn2trance's Avatar
Very interesting indeed. Subscribed to get more info.
Old 04-17-2009, 09:35 AM
I got the Shifts
phee's Avatar
i believe he is talking about the auto transmissions. seeing as the MT's dont "slip" per say.. they pop out.
however, i respect the fact that i could be totally wrong.
Old 04-17-2009, 09:42 AM
jisleyjr's Avatar
Originally Posted by SpecTro
Looks like those would be easy to get to, i recall seeing that side of the tranny when i was changing wheels last night.
I'd hate to throw away 70 bucks on good switches, anyway to test a switch?
Old 04-17-2009, 09:44 AM
jisleyjr's Avatar
Cheaper over here, http://www.hondapartsnow.com/Page_Pr...e=&appid=11234
Old 04-17-2009, 10:08 AM
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
It should be very easy to get to.. just remove the battery.. idk why this didn't occur to me before.. I've seen the same problem with the 6th gen Accords.
JCash23 (06-25-2022)
Old 04-17-2009, 10:45 AM
SpecTro's Avatar
So this are the ones i pointed right? They just added the 4th and 3rd clutch to it.
thassett (01-01-2012)
Old 04-17-2009, 10:55 AM
Majofo's Avatar
Yeah.. those are the right components.. Here's the Service Write-up for replacement. I guess it's much easier from below.. I'm assuming it can be done from up top too.. it's just the A/T temp sensor harness clamp bolts that can be tricky.
The following 2 users liked this post by Majofo:
iHeartmyHonda (04-13-2014), JCash23 (06-25-2022)
Old 04-17-2009, 10:57 AM
A Black TL
TL|GTX's Avatar
IS this just for A/T, or both?
Old 04-17-2009, 10:58 AM
Majofo's Avatar
just A/T.
Old 04-17-2009, 01:20 PM
No kidding? I didn't know this was a known problem with the Accords. It made me feel very good to see the clutches in person. There is no physical problem, at least in the form of holding power. The clutches are of a good size and there are enough of them. This enforces what my friend said about the electronics causing them to slip and self-destruct.
I believe he said something about the Automatic Transmission Rebuilders Association recommending they be replaced as normal wear and tear at 50,000 mile intervals.
It would be neat for those of us that are going to do this as preventative maintenence to check back into this thread as the mileage gets up there.
Old 04-17-2009, 01:34 PM
Majofo's Avatar
I had a '98 Accord (3rd car).. It ran very well until I let my family friends wife use it to commute.. long story.. anyways while they were driving it she noticed third holding / slipping. Took it to an old school Toyota tech.. he used a solvent to clean the valve body and replaced the pressure switches. I remember him telling me that he sees the pressure switches going out over regular intervals. It ran well after.
Old 04-17-2009, 06:24 PM
Babnik's Avatar
Can someone elaborate about pressure sensors for those of us who are mechanically challenged? Are they located inside the transmission? How hard are they to get to and replace and what tools are required?
Why only 3rd?
Old 04-17-2009, 06:57 PM
What would be the cost of this process .. for parts and then labor approximately?
Old 04-17-2009, 07:16 PM
He told me about $100 for both sensors and half an hour labor so roughly $140 for everything. Maybe $180 if your shop doesn't do half hours.
Old 04-17-2009, 08:02 PM
warren4066's Avatar
this sounds like an fun and easy DIY....but I need a video....very nice i hate cars
Old 04-17-2009, 08:23 PM
RPF1+RS3 FTW
AnthraciteAspec's Avatar
Good info, my tranny felt like it was going but I did the 3x3 flush and it feels fine now the slipping and stuttering went away. I think I am going to replace these as well now. I am a big fan of preventive maintenance and like many others on here I am very uneasy about the durability of my AT so anything that could bring me that extra piece of mind is great. I also see you have a transmission cooler, where did you buy that from? I want to pick one up.
Old 04-17-2009, 08:34 PM
Not where I should be
ML²'s Avatar
I had the "D" light flashing on me last week, happened once but that's all it took, so I brought it into Acura to read the codes. Turns out it was code P0782 which is the 4th pressure switch. Part number is 28610-RAY-003 and list price is $81.10 CAD and of course the part is a special order so they didn't replace it yet. It's under warranty but maybe I should have the 3rd switch added to the work order.
Thanks for the info.
Old 04-17-2009, 09:09 PM
200,000 mile club
mmade22's Avatar
Nice! Good looking out for the auto guys. It is worth the 140 dollars.
Old 04-17-2009, 09:16 PM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
Not to hijack the thread, but what about the 3rd gear issue for those of us with 6MT's?
Old 04-17-2009, 09:18 PM
TEAM INFIDEL!
Actrite04's Avatar
So one of you guys hurry up and change this so i will know if it works....lol Im settin at 85,000 miles so i am thinkin bout this real hard.
Old 04-17-2009, 10:30 PM
Nick337's Avatar
I mean for a hundred dollars its not that bad of an investment at all.
Old 04-17-2009, 10:48 PM
1st 3g Turbo TL-S
Xiomaro's Avatar
o thank god. i was going to get a new clutch in my Mt, and i was like "gay what if it's something else!"
Old 04-17-2009, 11:28 PM
Guys, this is in no way related to the manual TL. Auto only. Two very different animals.
Old 04-17-2009, 11:30 PM
I'm going to do it but at 74,000 miles, I'm not having any problems so I'm not expecting any changes. If it does shift better or different I will definately revive this thread.
Old 04-17-2009, 11:53 PM
Road Racer / Solo Addict
EL BAN's Avatar
Subscribed.. highly important info here..
Thanks OP!
Old 04-18-2009, 08:43 AM
Fulani has a TL's Avatar
After reading this thread, and thinking that I am at 71K figured I would do this, placed the order for the sensors yesterday, gonna pick them up after I get off work today, and figure out how the hell to install them!
I'll try to take some pics, but its gonna be with my 'berry so pictures may not be up to par!
Old 04-18-2009, 08:44 AM
BEAR-AvHistory's Avatar
Received 2,599 Likes on 1,581 Posts
Bring it in & get it fixed under the TSB. Trans must be completely disassembled to fix it.
Old 04-18-2009, 09:43 AM
#ForcedInductionFamily
WRXtranceformed's Avatar
My TL-S is just at about 60,000 miles right now. This might not be bad idea to go ahead and replace those even though my transmission is feeling fine right now and I just had the fluid replaced.
Old 04-18-2009, 09:58 AM
GO RANGERS!!!!!!!!!!!!!!!
e30cabrio's Avatar
Received 1,775 Likes on 1,234 Posts
I looked up the sensors on oemacura.com and see them on my 2001 CL. My transmission has 100k on it since it was replaced in 2005 under the recall, will replacing these help?
My car runs perfectly currently but I have no problem doing preventive maintenance.
Quick Reply: Very interesting conversation with my transmission builder on the TL
