Upper molding around front driver door
Hello, I need to replace the rubber trim/molding around the door.
I believe it is item #3 on the link below.
Can someone comment if this comes off and on easily? Looks pretty simple on the door, just don’t want to run into any surprises.
Thank you
2006 ACURA TL Parts - Discount factory (OEM) Acura parts and accessories at Park Acura OEM Parts
Thank you
its not super easy. the vertical one needs to come off first, and the side mirror. Then you'll have to pull off the molding, its held on by double sided tape. the molding WILL bend and be destroyed as you pull it off, theres no way around that and it's a one time use item, so install the new one carefully.
Thanks for the reply, but I think my link was incorrect and my description not very accurate. What I need to replace is the rubber trim that goes around the entire door.
Item number 4 in the link, I'm pretty sure this is correct part, but I'll post a picture for you guys tonight to ensure I got the correct item this time:
Thanks again for looking at this and apologies for the confusion.
Hope this is an easy install?
Door weather strip?
Comes off in 10 seconds.
Pulls right off.
Pulls right off.
tman570
06-11-2019 07:56 AM
