TL Switchblade Key FOB - How to Change Battery?
Old 01-02-2009, 10:14 AM
smr2112's Avatar
I have a TL Switchblade key that I am using with my '04 TL.
I am curious if anybody knows how to change the battery
in this fob?
There is a screw to open it, but the "button module" seems sealed
and I don't want to break it. Curious if somebody knows the trick.
This is the style FOB I am referring to -
Old 01-02-2009, 10:46 AM
New shoes on my
mglax13's Avatar
Check the manual. I'm like 90% sure the instructions are in there.
Old 01-02-2009, 11:27 AM
LoveMyTL-S's Avatar
I was looking at mine and it looks like there is a small Philips screw on the end of the FOB where the ring is for a key ring. I'm sure if you unscrew that you will able to open and change the battery.......
Old 01-02-2009, 12:32 PM
Don't feed the...WTF?
GLowrdr's Avatar
That generally is the #1 answer to everything, but since there are a few of us that have the modded switchblade keys, this won't appear in our manual (since we didn't officially have these keys for our cars).
Although, as I was typing that - I did think that you should be able to look at an 07-08 manual and find it in there. Check online for it.
Old 01-02-2009, 08:47 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
  1. take the remote out of the key by removing the screw from near the metal band
  2. push the lock and unlock button and the remote should come apart
  3. on the right side of the remote you will see a gap in the black plastic with a white rubber gasket, using a flat head pry and the case will come apart.
  4. the battery is underneath, size 3v, CR1616
Old 01-26-2009, 10:14 AM
smr2112's Avatar
Are you sure you are talking about the switchblade key?
This key has a little sealed module that the battery must be
within. The problem is that there is no obvious way to
open the module.
The Acura dealer said nobody has come in for a replacement
battery, so they have no idea how to do it.
Help!
Old 01-26-2009, 08:16 PM
meowevil's Avatar
in this fob?
Hold on, question! Where did you get ur switchblade key for 04 TL? I asked the dealer if the 07-08 switchblade key would work for my 06 TL, their responded "No, they wouldn't fit" The reason I ask, cuz I always want swtichblade key instead of one remote and one key
Old 01-26-2009, 08:25 PM
csmeance's Avatar
it was me or FLBUSA that made them.
csmeance's Avatar
open the module.
Help!
the module is not sealed, once I get my camera back i'll take a few photos of how to take it apart to change the battery.
Old 01-26-2009, 08:54 PM
CharlieCRX's Avatar
are you guys still making them???
Old 01-26-2009, 09:11 PM
nut854's Avatar
csmeance, once you add the pics, could you save this as a DIY in the 3g garage? This looks like great info. Once/if my battery dies, I'd love to be able to find this thread quickly. thnx
Old 01-26-2009, 09:18 PM
csmeance's Avatar
I am getting them worked on, Mr. Heel toe is trying something too.
Old 01-27-2009, 02:46 PM
meowevil's Avatar
Awsome, please keep us update. I would like to purchase one from you if possible
Old 03-05-2009, 04:29 PM
08 PMM/Black Tech
cFoo's Avatar
csmeance, any progress? I just lost my key. Would like to use this excuse to get the switchblade.
rockyboy
12-06-2022 02:29 PM
tman570
06-11-2019 07:56 AM
Aleax
09-11-2015 11:31 AM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
asahrts
09-04-2015 05:55 PM
Quick Reply: TL Switchblade Key FOB - How to Change Battery?
