Side Marker Lights (driver side)
Old 02-18-2017, 05:07 PM
Randy Mitchell's Avatar
Hello fellow Acura enthusiasts, im posting in this forum in hopes of finding a resolution to a problem im having with my 2006 TL. My drivers side marker lights will not turn on at all but the passenger side comes on fine. After making a trip to Advanced auto and getting back home with replacement bulbs, i came to find out that after removing the side marker light in the fender that there are no bulbs and that it is about 0.8 watts of what im assuming is an LED light. Is this issue caused by a blown fuse? All other lights minus the seat warmer light for the drivers seat work fine. Please help and thank you!!
Old 02-18-2017, 06:00 PM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
side marker light is a 3 LEDs bulb, you will have to replace the whole thing or buy after market and swap. However if you can solder then it also can be fix. OEM one is around $75.
Old 02-18-2017, 06:18 PM
Thank you so much for the prompt response!! Looks like ill definitely be ordering some soon.
Old 02-18-2017, 07:35 PM
WDPanda's Avatar
Get one off a part out.
