Question about Dash/Switch lighting
Old 09-23-2015, 01:25 AM
eastcoastguy's Avatar
So my first interior bulb went out today, the light in my Sunroof switch. I know lots of people have done the LED replacements, however I am OCD and the LEDs are too bright and dont match the other lights making it not look good in my opinion. I have searched and cannot find replacements that arent LED that are from sources other than Acura.
In my research I have found different Acura/Honda bulbs with different part numbers but are all switch and dash bulbs. Are these all the same just different part numbers and brightness. For example Acura 35835-SEP-A01 as opposed to Honda 35505-S84-B02?
If I have to I will just go to the dealership and get a bulb but I wanted to find out some other options first.
Old 09-23-2015, 06:29 AM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
There is a difference between bulbs for each button.
Some are brighter or dimmer than others, and some are more green or yellow than others.
You can change them around as they all fit, but it might not match the surrounding bulbs in term of colour and brightness.
35835-SEP-A01 is the one you want to replace the original
The sunroof button is one of the easier bulbs to change.
The other bulbs require much more work like removing the steering wheel or disassembling the console. Still easy work, just more work.
mada51589
05-03-2022 08:54 PM
eastcoastguy
09-24-2015 02:07 PM
wusty23jd
09-24-2015 11:41 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: Question about Dash/Switch lighting
