PSA!!! Don't buy Gates Water Pumps
Old 07-22-2015, 02:16 PM
  #41
#1 Super Guy!
94eg!'s Avatar
I suppose the trolls are trying to say I messed up the install of a device held on by 5 M6 bolts. You would obviously be wrong. I've installed at least a dozen water pumps and never had a problem with any OEM Honda pumps. Of the two Gates pumps I've installed, this one pooped out after 40k and the other one (another Pilot) didn't get much use since the transmission pooped out within 5k miles. This Gates pump in my wife's Pilot was a lemon.
PS: You can't really screw up installing this pump, unless the gasket flops out of it's groove and gets stamped between the pump & the block (in which case you would have an immediate leak on startup). M6 bolts torque their heads right off with very little effort. Long before the (im)possibility of distorting/crushing the aluminum pump in any way. Then the 3 motor mount thru bolts get torqued to 33lb/ft with a torque wrench. No way they are doing any water-pump crushing (or whatever).
You guys are grasping at straws here.
Old 07-22-2015, 02:29 PM
  #42
01acls's Avatar
I have to ask. So you knew oem was pretty much a no brainer. Why did you take a chance on something other than oem?
Old 07-22-2015, 02:38 PM
  #43
#1 Super Guy!
94eg!'s Avatar
Well, I pretty much fell for the convince & price of the all-in-one kit. I trusted the OEM quality of the Gates timing belts (since Honda uses them on 9k rpm piston engines), so I figured they would also provide a good aftermarket water pump too. I was wrong, and almost paid a huge price for it. I made this thread to share my personal experience with others.
Old 07-22-2015, 02:43 PM
  #44
01acls's Avatar
Yeah nothing like school of hard knocks to drive home the point.
Old 07-22-2015, 06:01 PM
  #45
t-rd's Avatar
How do you know anything? We are probably just living in the Matrix and the coolant leak is just a bunch of pixelized green dots! If anyone is trolling any water pump, then he isn't doing a good job. I haven't seen anyone do a bad review of an Aisin water pump. So go get another Gates Chinese water pump, install it, then and see if it fails. Gates is a great brand, I use their drive belts and auto tensioner, but I wouldn't use their water pump. Some of you are in flat out denial about a clear failure, with pictures here, like Marcus in the suspension forum continuously denying there is a problem with the Ingalls Engineering rear control arms giving problems. Do what you like.
94eg! (07-22-2015)
Old 07-22-2015, 07:38 PM
  #46
YeuEmMaiMai's Avatar
I do not like GATES belts at all... Previous owner put one on the car at some point and they recommended changing it at 61K. WTHeck? OEM belts are (for Subaru 105K or 7-8 years). Needless to say I took the belt off and replaced it with an OEM one.
Old 07-22-2015, 07:49 PM
  #47
t-rd's Avatar
OEM serpentine belt = Bando. My OEM serpentine belt started squeaking after 40k miles. 105k miles? You are really pushing it.
Old 07-23-2015, 10:35 AM
  #48
#1 Super Guy!
94eg!'s Avatar
For my 05 TL, the OEM replacement serp belt is Mitsuboshi. You can get it in a Mitsuboshi 6PK2135 box for a lot less. I still have the original belt on my 05.
BELT, COMPRESSOR (MITSUBOSHI) for 2005 Acura TL|38920-RCA-A03
Mitsuboshi 6PK2135M Serpentine Belt
Looks like the later TL's use Bando:
http://www.oemacuraparts.com/acura/t...mpressor-bando
Old 07-23-2015, 10:38 PM
  #49
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
OP, were you using OEM coolant?
Old 07-23-2015, 10:47 PM
  #50
kevykev1969's Avatar
I'm glad I read this because I was going to order the gates component kit tomorrow for 00 TL 3.2
Old 07-24-2015, 08:09 AM
  #51
#1 Super Guy!
94eg!'s Avatar
Yes I was. It's the only coolant I use. I have 3 gallons of it sitting in my garage right now, along 4 empty ones in the recycling bin.
Old 07-24-2015, 03:20 PM
  #52
nfnsquared's Avatar
Originally Posted by 94eg!
....PS: You can't really screw up installing this pump, unless the gasket flops out of it's groove and gets stamped between the pump & the block (in which case you would have an immediate leak on startup). M6 bolts torque their heads right off with very little effort. Long before the (im)possibility of distorting/crushing the aluminum pump in any way. Then the 3 motor mount thru bolts get torqued to 33lb/ft with a torque wrench. No way they are doing any water-pump crushing (or whatever)....
Why Do Water Pumps Fail?
Old 07-24-2015, 03:34 PM
  #53
nfnsquared's Avatar
Not true, go on Amazon and search for the Gates timing belt kit then read the reviews. There is a shop owner on there that reported 30% Gates pump failures....
Link?
Old 07-24-2015, 03:49 PM
  #54
#1 Super Guy!
94eg!'s Avatar
Old 07-24-2015, 05:12 PM
  #55
Registered Bike Offender
Vlad_Type_S's Avatar
So then it's owned by Wisconsin?
rockstar143 (11-01-2015)
Old 07-24-2015, 06:51 PM
  #56
t-rd's Avatar
http://www.amazon.com/review/R7FRH8E...ore=automotive
there are follow-up comments after this guy's comment also regarding other failures.
Old 07-24-2015, 07:20 PM
  #57
nfnsquared's Avatar
Amazon.com: Amazon Customer's review of Gates TCKWP329 Engine Timing Belt Kit with...
Still looking for your claim of a 30% failure rate...
91 reviewers and only 3 claim failure/leak. Heck, some of them may not even know that some weeping is normal or they could have a myriad of other coolant system issues which led to the failure, not to mention being clueless when installing...
Old 08-24-2015, 09:26 AM
  #58
rkpatt's Avatar
There is to much labor involved to redo this job because of a premature part failure. I want everything to last the full 105K mi interval. Paying more for the highest quality parts on the front end makes sense. No Gates WP for me.
DMZ (08-24-2015)
Old 08-25-2015, 10:55 AM
  #59
nfnsquared's Avatar
Again, only 3 reports out of 91. I have 100K on my Gates kit/water pump with no issues. I'll be using the same kit when I do my 2nd TB change in 2 months...
Old 09-01-2015, 05:00 PM
  #60
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
I thought Gates was OE quality being an OE supplier. I'm sure a number of those failures are related to poorly installed pumps. If the OE pump has the lips to hold in gasket/o-ring, get that. I know a lot of people on gates pumps going on their 2nd timing belt change, not one issue.
Old 10-18-2015, 07:27 PM
  #61
BillMFD3's Avatar
I'll just add my experience: gates kit 1.5 years 30,000 miles. Water pump failed today. No indication of a problem until I saw coolant leaking under the car.
01acls (10-18-2015)
Old 10-19-2015, 07:34 AM
  #62
Needs a 930
BeezleTL85's Avatar
Gates kit, 1.5 yrs, 50k miles
Old 10-19-2015, 08:33 AM
  #63
#1 Super Guy!
94eg!'s Avatar
Is that 1.5 years and still running good, or 1.5 years and it failed? Just curious.
Old 10-19-2015, 01:00 PM
  #64
Needs a 930
BeezleTL85's Avatar
Failed
Old 10-19-2015, 03:23 PM
  #65
nfnsquared's Avatar
Gates kit: 4 years 9 months, 105K, still going strong.
Old 10-20-2015, 03:14 PM
  #66
4th Gear
FlyingBoat's Avatar
How about the Dayco WP329K1A kit? Mechanic recommended it to me, saying he has installed hundreds of Acura/Honda TBs and has not had a single problem with them.
They cost a little more than the Aisen kit at $194 at Autozone, though I can get much cheaper with coupon codes etc. In comparison Autozone sells cheap Duralast kits for $74, so these Dayco kits are priced higher and Amazon comments say the Dayco are Japanese parts, so it doesn't look like cheap low quality parts. Since the Mechanic is installing it, I think I will go with his recommendation.
Old 10-20-2015, 03:23 PM
  #67
Received 8,584 Likes on 6,630 Posts
decent reviews (although only 7)
Amazon.com: Dayco WP329K1A Engine Timing Belt Kit with Water Pump: Automotive Amazon.com: Dayco WP329K1A Engine Timing Belt Kit with Water Pump: Automotive
Old 10-20-2015, 05:01 PM
  #68
nfnsquared's Avatar
$158 at rockauto.... Best warranty I've seen on a TB kit.
http://www.rockauto.com/catalog/raframecatalog.php?catalog=33&partnum=WP329K1A
Old 10-21-2015, 08:58 AM
  #69
BillMFD3's Avatar
Interesting:
DAYCO Warranty Information
12 months/12,000 miles. Timing Belt Component Kits/60,000 miles, or the life of the automotive manufacturer's original recommended replacement interval
My water pump turned out to have a bad shaft seal.
Old 10-21-2015, 09:09 AM
  #70
Jakes_tl's Avatar
I would stay with OEM or Aisen kit. Not sure about Dayco
Old 10-21-2015, 09:33 AM
  #71
BillMFD3's Avatar
Talking
Agreed, I got a Aisin wp off rockauto as a replacement.
My weekend car doesnt have any timing to worry about...
Old 10-22-2015, 10:21 AM
  #72
rkpatt's Avatar
At one point years ago the Dayco kits contain China made tensioners and water pumps. Maybe not now (I suspect GMB). Their warranty doesn't mean much to me unless it will cover labor and consquential damages (which of course, it does not). I will stick with OEM or Aisin.
Originally Posted by BillMFD3
Interesting:
Old 10-22-2015, 10:45 AM
  #73
4th Gear
FlyingBoat's Avatar
How do you tell if from China? Will the parts be marked? Review for this kit on Amazon said Japanese parts. An advantage with the Dayco is I can buy from AdvanceAuto or Autozone and return instead of shipping back to Rockauto or Amazon. Also, price ends up being cheaper because I can use coupon codes and shopping portals.
Main thing though, is I would prefer to use what the Mechanic recommended. Both due to his experience as well as if something does go wrong he could blame it on due to the part not being the one he said to get.
Old 10-22-2015, 11:00 AM
  #74
nfnsquared's Avatar
You'll be fine with Dayco. Quit worrying.
Old 10-29-2015, 01:14 AM
  #75
2002 CL-S went 118K on original timing belt and serpentine belt
2003 Subaru now has 30K on replacement Subaru timing belt and serpentine belts
Both Acura and Subaru state that their belts will go 105K and based upon my experience, I'd say they are right on the money.
Old 10-31-2015, 10:48 AM
  #76
4th Gear
FlyingBoat's Avatar
Well....You can buy the Gates kit without the waterpump (TCK329), which includes the Koyo rollers for $54. The Aisin BTH-001 tensioner is another $56. Then all you need is the water pump. New Honda/YNA pumps sell between $60 & $90 on ebay, or you can buy the Aisin WPH-801 pump for $64.
This gives you a 100% OEM package which is what most of us seem to be after here, for only $174 (same price as the Aisin kit with a non-oem timing belt).
I see this kit on ebay for only $39.95 for genuine Honda pump. Though it doesn't include gaskets. http://www.ebay.com/itm/like/400803945355?ul_noapp=true&chn=ps&lpid=82 Looks a little scratched up too even though it says New Bulk.
Thinking to go with what you recommended above as OEM except used the Aisen WP. Cost me $186 on Amazon, but I used 15%+ off GCs. So comes out close to what I could have got the Dayco kit for, which would have been $50 off $200 at Advance Auto. Advance Auto has the Aisen kit for $300 in comparison. Best I could find for OEM WP w/gaskets was 117 compared to $70 for Amazon Aisen WP.
Son bought an 07 TL with 91K on it. So it is not past miles, though well past the years.
Old 10-31-2015, 11:46 AM
  #77
nfnsquared's Avatar
I see this kit on ebay for only $39.95 for genuine Honda pump. ..
Yeah, "bulk packed" would scare me away also, plus the fact that they "may have been installed"...
Old 11-01-2015, 06:10 AM
  #78
BillMFD3's Avatar
Picture of my failed gates wp
Old 11-01-2015, 07:56 AM
  #79
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
my shit better not fail...
01acls (09-18-2019)
Old 12-14-2015, 02:24 PM
  #80
rkpatt's Avatar
The Gates WP recently failed on my 1994 Ford F250 part-time hauler after 3 yrs / 17 k mi. At least it was relatively easy to replace.
Quick Reply: PSA!!! Don't buy Gates Water Pumps
