Painted emblems
Old 10-10-2013, 11:31 PM
Dbatt3's Avatar
Painted emblems
I'm new to the forums and the first mod I want to do is paint my emblems black so I wanna see what some of yalls emblems. I personally don't like the plastidip look. Post pictures of ur emblems and how u did it. Thanks
Old 10-11-2013, 12:39 AM
Noober's Avatar
This is plasti-dipped.
Hope it helps.
Old 10-11-2013, 12:54 AM
mzilvar's Avatar
Here:
Those are painted. Color is dupli-color's enamel gloss black, I painted them as follows:
1 - Remove emblems, use dental floss inbetween the painted surface and emblem to cut the double stick then goo-gone to remove the residual double stick.
2 - Scuff emblems - I used gray scotch brite pads to scuff them until water sheets on the emblems. You don't want it to bead up at all, if it does keep scuffing until water sheets. Let it dry completely before proceeding and clean with dish soap like dawn to de-grease.
3 - Hit the emblems with duplicolor prep spray & allow follow the directions to let it evaporate
4 - Spray the emblems with 2 light coats of bull-dog, following recoat windows, careful with the bulldog it'll run really easy if oversprayed
5 - Paint with dupli-color enamel gloss black
- Coat 1 is light, dusting
- Coat 2 is also light, full coverage
- Coat 3 is medium
- Coat 4 is medium/heavy
Follow re-coat windows between each coat
6 - Paint with Spraymax 2k Glamour Clear coat
--- Warning here .. the spraymax 2k contains isocyanates and is extremely hazardous to your heatlh. Standard OV filters on your respirator last less than 10 minutes around this chemical (check the sheets) and it's odorless. It can cause major respiratory problems and you can become 'sensitized' to it and have an asthmatic reactions anytime you're near it in the future, for the rest of your life. Check the hazards, its not pleasant stuff and take appropriate precautions. I used a paint booth and put new filters on my respirator before starting to spray. Also wore gloves, coveralls, non-vented goggles and sprayed the paint so it would flow away from me and toward the paint booth ventilation. And I exited the paint booth between coats while I waited about 15 minutes for my re-coat window each time.
- Spray it on in same way as you did the enamel black, following re-coat windows on the clear coat.
The spraymax is dangerous for CC due to the isocyanates, just google the chemical name and you can read about it. But you're not going to find another rattle can clear coat that has as good of a finish as you'll get from the 2k spraymax CC.
My paint has been on the emblems for over a year now and no chipping or flaking at all.
I used one-shot red pin-striping paint for the A-SPEC lettering after the clear coat cured.
Also carefully used an exacto knife and 3M double-stick tape to re-affix the emblems. I put the double stick on the back of the emblems before putting them back onto the car.
The following 3 users liked this post by mzilvar:
EvilVirus (10-11-2013), eyedrop (10-11-2013), LoveMyTL-S (07-05-2019)
Old 10-11-2013, 07:43 AM
Slot Machine Lubricator
1black_seven's Avatar
Yeah I just dipped mine then did a triple layer of clear coat gloss. It's easy, painless, and probably wont give you cancer.
The following 4 users liked this post by 1black_seven:
GKinColo08TL (10-11-2013), LoveMyTL-S (07-05-2019), nttstt444 (10-11-2013), thoiboi (10-12-2013)
Old 10-11-2013, 10:51 AM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
Its funny guys OP said he doesnt like plasti dip at all.
Good job mzilvar on the write up and pic
Old 10-11-2013, 11:47 AM
nttstt444's Avatar
I used to have the A on the trunklid plastidiped with clear coat over it, it looked good(not as nice as mzilvar's) but good for the amount of work I did. And if you get tired of it and want to go back to stock plasti dip peals right off.
Old 10-11-2013, 01:26 PM
EvilVirus's Avatar
Yeah that is the beauty about it plus they come in colors now. Granted I would rather have something better (black chrome) but I have been lazy about finding it and doing the work.
Old 10-12-2013, 12:28 AM
nttstt444's Avatar
Aside from the nasty chemicals that spraymax clear coat looks like good stuff. They don't give it away tho! $20+ a can.
Old 10-12-2013, 01:47 AM
mzilvar's Avatar
^^ Yah thats true it is expensive.
I actually have another can sitting on my dresser right now. Not sure what I'm going to use it for, I was originally going to use it to re-paint my C-MOD grill but decided to have the body shop re-do it NBP with some other parts on the car when I have my RonJon bumper installed.
Old 10-12-2013, 07:32 PM
This is plast-dip and clear coat gloss. Emblem and rims.
Old 10-12-2013, 11:55 PM
I'm Craig
cjTL's Avatar
Originally Posted by mzilvar
Here:
You painted an A-Spec badge...
Old 10-13-2013, 12:01 AM
mzilvar's Avatar
lol .. yep
The lettering is red now, I'll get a better picture of it later.
Old 10-13-2013, 09:06 AM
EvilVirus's Avatar
Well at least now no one may not want to steal it since its painted
Old 10-19-2013, 07:41 PM
mzilvar's Avatar
Here's the photo of it with red lettering:
I need to wash my car.
When I painted I did everything wet on wet, only took a little over an hour to have all of the paint on from start to finish. If you wait too long your paint won't cure or it'll peel. Once the paint has cured, you're supposed to wait 7 days and then scuff it prior to painting it again or you won't get any adhesion. Paint has two ways to hold on.. mechanical adhesion (from the scratch lines) and chemical adhesion to prior layers.
Once everything was cured I did the lettering, had to scuff the inside of the emblem where the lettering was carefully, then painted by hand with a paint brush and wiped the excess off the surface while it was wet.
I used pin-striping paint for the lettering (one-shot) which is designed to go on top of clear coat.
Old 10-20-2013, 06:24 AM
yn1scott's Avatar
A few pic's of my CBP TypeS. All done with Plasti'Dip. Will be doing the grill shortly! Hope you like...
Attached Thumbnails Painted emblems-photo5_zps4beb988c.jpg   Painted emblems-photo4_zps2655abb2.jpg   Painted emblems-photo3_zps6d8a1c22.jpg   Painted emblems-photo2_zpseb6318c3.jpg   Painted emblems-photo1_zps38d8f7fd.jpg
Painted emblems-null_zpsc0df066f.jpg   Painted emblems-null_zps4cc125ef.jpg   Painted emblems-null_zps8ea0b234.jpg
The following 3 users liked this post by yn1scott:
AlexGonzalez (04-15-2019), LoveMyTL-S (07-05-2019), sfkd119 (06-29-2019)
Old 10-20-2013, 01:18 PM
story.customz's Avatar
Remove the emblems. Base coat with plasti dip then dupli colour engine enamel gloss black on top. It'll come out perfect, and if you ever decide you want to go back to chrome, it'll peel off.
Old 10-03-2016, 12:03 PM
EvilVirus's Avatar
Old 10-03-2016, 12:45 PM
TypeSZilla's Avatar
that Murdered TLS... is niiisshhhe!
Old 10-07-2016, 01:56 PM
Cold Business
SocomM4's Avatar
Old 10-16-2016, 01:51 AM
Cryhawk's Avatar
How do you re-apply when emblems after you detach them using dental floss?
Old 10-16-2016, 07:15 AM
Mr. Showtime's Avatar
Emblem adhesive. https://www.walmart.com/ip/3M-Plasti...fl-oz/16913676
All of your typical auto stores usually has it too
Old 06-29-2019, 04:17 AM
sfkd119's Avatar
Type S Badge
How did you paint the Type S Badge black? Did you take it apart? I'm looking to do the same thing.
Old 06-29-2019, 07:54 AM
Received 16,260 Likes on 11,971 Posts
"all done with plastidip"
just tape it up. then spray paint it
Old 06-29-2019, 07:55 AM
and
iRaw
ILX Photograph Gallery
30
08-05-2016 04:41 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Quick Reply: Painted emblems
