The Official "Does This Fit My Car?" Thread
#243
'10 Hyundai Genesis Coupe
Originally Posted by stillhere153
WHOOPS... thanks for the correction I overlooked the part number real fast...
... still no gain if you don't piggyback...
Well I guess, the only gain I'll notice is probably the 2lbs of weight reduction with a lighter cam, but I guess I'll just stick with the lighterweight IM for now.
My plans are going to be;
Lightweight pulley
Lightweight battery
CF hood (color matched to the TL anthracite)
Type-S IM
Racing brake two piece rotors (each rotor is 6lbs less than stock)
Racing Seats
That'll probably save me 130lbs or so.
#244
94 DC4 RS LSV/Turbo
Originally Posted by MWalsh9152
ok I'm feeling lazy and dont wanna search no mo tonight
Year: 2008
Trim: Type S
Color: KBP
Item you would like fitment verified: I have Axis supermesh (similar to penta) 19x8.5 45mm offset with a 235/35 from my 06 5AT sitting in my store room. What size spacer is best, and what bore for hubcentric?
Year: 2008
Trim: Type S
Color: KBP
definitely try the washer method.... sorry I didn't post a reply sooner on this thread just been busy with acurazine member exhaust installs
#245
94 DC4 RS LSV/Turbo
Lightweight pulley
Lightweight battery
Type-S IM
Racing Seats
Lightweight pulley
Lightweight battery
Type-S IM
Racing Seats
sounds like a plan to me... 15lbs braille ftw
#246
94 DC4 RS LSV/Turbo
Originally Posted by dr_brains510
hey Al, will a P.C.D. (pitch circle diameter) of 10 x 100/114.3 with an offset of 42 fit any Acura models? If so, which ones? Also, how many lugs is it? Thanks.
no idea I would stick to 5x114.3... unless that was a typo and you ment 5x100/114.3 in which case it fit but it will have a whole bunch of holes in the center
#247
hEY ALL
I installed my front lip for my type S but it doesnt fit tight. Its like hanging off just a lil from the from and i cant get it to sit properly on the car. Am i missing something that keeps it together cuz only I see that keeps it on the car is just the double sided tape and the bottom clips........Call me crazy but that just cannot be. Acrua isnt that stupid I would hope.
Please help
Please help
#248
94 DC4 RS LSV/Turbo
Originally Posted by NocturnalTypeS
hEY ALL
Please help
Please help
#249
Year: 2007
Trim: TYPE S
Color: WDP
Item you would like fitment verified: i am drop on aspec's and as you know the drop itself isnt much. whats the best size tire i should go with and still have some kind of a drop?? i am trying to limit wheel gap as much as possible but still have a nice soft ride. wheels are aspec's 18x8.5.
thanks AL!!
Trim: TYPE S
Color: WDP
thanks AL!!
#250
94 DC4 RS LSV/Turbo
Originally Posted by lenjaiah
Year: 2007
Trim: TYPE S
Color: WDP
thanks AL!!
Trim: TYPE S
Color: WDP
thanks AL!!
245/40-18
255/40-18
Gap Cutter... Install 10mm spacers on all 4 corners, that will make the wheel gap slammed shut
#252
Transmission: AT
Year/Trim: 07 Type S
Wheel Make/Model: Tenzo DC-6
Wheel Size : 18x8
Wheel Offset : +35
Tire size: 245/40 18
If lowered (amount): 1 inch on eibach prokit
I have installed the wheels and they look pretty wide... I am scared that when I lower the car that they will rub inside the fenders. So my question is, do you think I will have a clearance issues if I lower my car (Eibach prokit, stock struts) with these wheels and tires? (I did not get a response in your wheel/tire thread so I thought I would try here)
Wheel Size : 18x8
Wheel Offset : +35
#253
94 DC4 RS LSV/Turbo
why not 235 and instad u recommend 255??? whats the cons about a spacers?
235 is good for 8" wheel, 245 and 255 are better on a 8.5"
some believe spacers are bad for numerious reasons... but if the spacer is hubcentric you will be fine
#254
94 DC4 RS LSV/Turbo
Originally Posted by Lileasy123
Transmission: AT
Wheel Size : 18x8
Wheel Offset : +35
Wheel Size : 18x8
Wheel Offset : +35
#255
I thought you wanted to close the wheel gap... spacers and wider tires do this real quick
10mm spacers... do i need ext lugs?? or stock lugs will do??
what i was trying to ask... since i am drop on aspec. whats the best tire to go with so it looks MORE on the drop. as of right now, stock 17's, i have a 2 finger gap and i wanna keep that 2 finger with my 18's
#256
94 DC4 RS LSV/Turbo
yea with the spacer it will close the gap by putting the wheel closer to the fenders...
as for tires, when you go bigger on wheels you get less sidewall.... soo unless you went 225/45-18 it wont be any different you know.... so go wider to close the gap
#257
hey everyone i just bought about 2 months ago a 2008 tl type s and i have a set of 20x8.5 45 offset foose speedsters that came off my 2003 tl type s im just wondering if these rims would fit my 2008 type s?
#258
94 DC4 RS LSV/Turbo
You'll have to test fit the fronts... Likely-hood of requiring a spacer is high
Shame-less-plug: I have 2 pairs of spacers in the blackmarket for sale.. A 10mm and a 13mm pair
Test fit method: get a bag of washers measure the thickness, usually they are 1mm or just above 1mm thick.. Put 5 washers on each wheel stud and test fit, if it clears, you'd likey need a 5mm spacer... Continue the method till the wheels clear
#260
Looking for new mods
^^^^YES it will, However the type-s comes with 4 bolts and 3 clips. There is no template for it, since this is considered a part and not and accessory. Some people here use double sided tape. Any skilled body shop can installed it with bolts.
#262
Jokerman
Transmission: AT
Year/Trim: 04 Base
Wheel Make/Model: Tork Imagine
Wheel Size : 19x9
Wheel Offset : +40
Tire size: 245/35 19
I know 19x8 will fit, but i am looking at getting the wider wheel. I know the 245/35 tire will fit, but will that be stretching it. Should i go to a 255/30 or 255/35 tire.
Year/Trim: 04 Base
Wheel Size : 19x9
Wheel Offset : +40
#263
94 DC4 RS LSV/Turbo
245/35-19 is not a stretch on a 19x9... 235 on the other hand is definitely a stretch
255/35 will throw the speedo off so you'd want to run 255/30... also as an alternative just in case you'd live to go even wider 265/30 works also...
#264
Jokerman
I did a lot of math and it looks like the 245/35/19 is about 11mm taller than the stock rim tire setup which is not even 1/2 inch. I just wanted to make sure that the 9" wide rims would fit the front.
#266
Jokerman
U'll be ok, I am rolling on 18x9 all around... no worries...
#267
94 DC4 RS LSV/Turbo
They will not comeout passed the fender
19x9 +35 fits aswell... You have an extra 5mm to play with so that you can roll on the tires of your choice
I am guaranteeing they fit
On one condition... Pm me cuz I wanna see pics of how hot they gonna look on all 4 corners.. 1.75" lips or 2"???
#268
Jokerman
according to the manufacturer website we are talking about a 3" lip. With the chrome lip and black gloss spokes i am sure these will look great. As soon as they are on, be rest assured that there wll be pics of me putting them on and the car sitting on them after i am done.
#269
94 DC4 RS LSV/Turbo
3" lip all the way around ... dude ur car is sooooo gonna be begin for a drop... I will let you know how the wicked camber kit goes
#270
Jokerman
i plan on dropping it around the end of sept begining of October. So it will still look nice but when the drop happens it will look sick. I hope that camber kit goes well . I saw that it was for a TSX, but hopefully you will not run into any problems and we now have a new choice for a camber kit.
#271
94 DC4 RS LSV/Turbo
Since this is a fitment thread I will take that as a fitment question
Yes the wiked tuning rear camber kit for the 1st gen tsx fits the 3rd gen tl... In fact it allows more adjustibility than the ingalls camber kit (only reason why I bought it.. That and it was $40 cheaper)
#273
94 DC4 RS LSV/Turbo
Originally Posted by Vietnastee
Would you happen to know 100% if the right part number for the honeycomb grill for the 07-08 TL-S rear bumper is 71504-SEP-A20ZA? I've emailed Tim at hondaacuraworld but I haven't gotten a response from him yet. Thanks in advance.
#274
Year: 2007
Trim: TYPE S (6MT)
Color: MRP
I bought a set of BASE 2008 TL Wheels for winter use on my 07 TLS 6MT.
I'd like to know if they will clear the Brembos in front without spacers. If not, what size spacers will I need to get and where from?
Trim: TYPE S (6MT)
Color: MRP
#275
iScrape going into
Originally Posted by ChicagoBurbs
Year: 2007
Trim: TYPE S (6MT)
Color: MRP
Trim: TYPE S (6MT)
Color: MRP
#276
I have a:
2004 Base automatic with NO aspec kit
and was wondering if the fog lights or driving lights (whatever they are called, but the ones on the lowerer part of the front bumper) off the newer 07 and 08 models will fit in the empty space i have on my car?? Thanks!
#277
94 DC4 RS LSV/Turbo
Year: 2007
Trim: TYPE S (6MT)
Color: MRP
Trim: TYPE S (6MT)
Color: MRP
#278
94 DC4 RS LSV/Turbo
Originally Posted by blessdylan
I have a:
Alternatively you can put the fogs on then put the type s front aspec kit and you will have no fitment issues
#280
Fits without any modification required... You'll have about a credit card thick sized amount of space which is all you need...
